Old 09-13-2005, 08:49 PM   #1
superGT's Avatar
oil in the wrong place
i have a 2000 mustang GT and the other day i looking under the hood and i found oil under the manifold, right between the valve covers. does anyone know where this might be coming from, cuz i have no idea... and where can i have a replace windshield...stupid rocks on the freeway!!!! :larry03gt
JUST LOOKS STOCK!!!
superGT is offline   Reply With Quote
Old 09-13-2005, 09:27 PM   #2
Look at where the leak is coming from...........Coluld be a valve cover gasket or head gasket..........
Old 09-14-2005, 10:46 PM   #3
you smell that?!
311-420's Avatar
ooooh shiot....did you change motor oils from regular to synthetic? that can cause a break-down of the seals(gaskets). its good to use one or the other and stick to it.
04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
311-420 is online now   Reply With Quote
Old 09-15-2005, 11:55 PM   #4
superGT's Avatar
same oil
the thing i'm the second owner... when i got i used the same oil but i don't know the owner used.
JUST LOOKS STOCK!!!
Old 09-16-2005, 12:01 AM   #5
you smell that?!
311-420's Avatar
well, if it makes you feel any better my steeda has blow-by and needs a complete rebuild as well as either another t5 or new synchros
Old 09-16-2005, 01:02 PM   #6
Here is what I can recommend doing. Clean the oil all up around the intake and start it and let it run to see if you see any seepage. If not go for a drive and come back and take a look at it to see if you see a leak. Also check your PVC valve to see if it is clogged up. If it is bad it will cause too much crank case pressure and oil leaks can start.
Old 09-16-2005, 02:29 PM   #7
you smell that?!
311-420's Avatar
this guy knows his shiot. carbon deposits suck nuts :thumbdown
