Results 1 to 12 of 12
Thread: oil pan gasket 89foxbody
    Newbie fresh fish!
    Jun 2010
    san antonio
    dose any one know a faster way to change the oil pan gasket on a 89 foxbody
    May 2008
    get the one peice rubberized gasket. It makes it a little easier.
    Newbie fresh fish!
    Jun 2010
    san antonio
    yea but how to remove it from the car to me it is a bitch
    fox-man Regular Member sticks905.0's Avatar
    Aug 2005
    san antonio tx
    remove k member or un bolt the motor mounts and jack up tranny (which is harder to do than removing k member.)
    Oct 2006
    Denton
    you dont have to completely remove the k member but it is easier imo.... a lot of people just drop the rack, and weasel the old one out and the new one in.. but i dont like to do that 'cause you can't really clean the surfaces.
  6. #6
    Newbie fresh fish!
    Jun 2010
    san antonio
    well i tried to do it myself but still leaking not as bad but still leaks. now dose anybody know a place to fix it and what is the price thank u
  7. #7
    Dec 2007
    Marion
    Did you use the one piece rubber gasket? If you did, that is most likely all or part of your problem. The one piece gasket is for '91 and later car and will cause a leak in the rear on earlier cars. I have a way of getting the pan out without dropping the K member. I have found that it is best to remove the pan, so you can properly clean the pan and block and let the block dry over night before installing the new gasket.
  8. #8
    Newbie fresh fish!
    Jun 2010
    san antonio
    how is that bro. so 91 and up is for the ruber gasget one piece . what is the one for 89 stang. how do u take it off . help how much u charge to do it
  9. #9
    Dec 2007
    Marion
    Ford changed the oil pan design in late '90 or '91, if you can get your hand on both style pans and look at the corners where the pan goes under the crank in the rear, the pans are shaped differently. I used to try to use the rubber one piece gasket on the earlier cars many years ago and they always leaked, so I would have to redo them. Recently I have bought two rubber one piece gaskets and used them one the earlier pans, because they were listed as being correct for that year, both leaked in the rear I had to go back and replace both. The earlier cars use the four piece cork gasket with rubber end seals. To replace a pan gasket is about $300 labor plus parts, which consists of pan gasket, oil, oil filter and a can a brake parts cleaner. The parts should be $50 or less.
  10. #10
    Dec 2003
    SanAntonio
    You should be able to get it out by just lifting the engine. Undo the mtr mts and use a hoist to lift it up. Then drop the pan and snake it out from the rear.
    85GT FACH1 FINISHED
  11. #11
    Newbie fresh fish!
    Jun 2010
    san antonio
    just got back this shop on culebra whants to charge me 450 to fix my oil pan gasket
  12. #12
    Dec 2003
    SanAntonio
    If you have tools and a jack with stands you can do it yourself....It really isnt that hard
    85GT FACH1 FINISHED
