Old 05-25-2008, 01:11 PM   #1
mando99's Avatar
overhauling my 4.6 need some help??????
trying to find a overhaul kit and some suggestions on cams been looking on many sites but cant seem to find them. any suggestions will be great!!!!!!
mando99 is offline   Reply With Quote
Old 05-26-2008, 02:01 AM   #2
LOL @ your mom
Trader Rating: (22)
A head gasket set will include from the timing cover and up, head gaskets, manifold gaskets, intake gaskets, plenum, iac, egr, t-stat, cover gaskets, water pump, front crank seal, injector o-rings, valve seals and more odds and ends.
Then you just need the oil pan, rear main, & oil filter adapter.
Old 05-28-2008, 08:41 AM   #3
mando99's Avatar
thanx do u happen to know a good website I can find them
Old 05-28-2008, 10:19 AM   #4
LOL @ your mom
Trader Rating: (22)
Summit sells a PI head swap kit for under 200, comes with all you need for head work. As far as the rest, most parts stores carry them, save the shipping, buy locally.
Old 05-29-2008, 11:42 PM   #5
mando99's Avatar
thanx will check it out
Old 05-29-2008, 11:56 PM   #6
4.6stanger's Avatar
What are you plannin on doin?? Just a rebuild, or rebuild with headwork, cams and so on??
What will it be, Breakin 12's or Breakin drivetrain.
Old 06-01-2008, 10:53 PM   #7
mando99's Avatar
Doing a rebuild but decided that now that its getting worked on decided to get cam and head work done hopefully start in September
Old 06-01-2008, 11:26 PM   #8
02silverstang's Avatar
Send a message via MSN to 02silverstang
4.6 rebuild
summit racing has the complete overhaul kit with pistons and bearings and most of the stuff for a more stout 4.6 2v with out breaking the bank .
02silverstang is offline   Reply With Quote
Old 06-02-2008, 09:11 AM   #9
mando99's Avatar
thanks alot of help going to check out today !!!
