Old 07-06-2007, 07:00 AM   #21
keg65's Avatar
Originally Posted by 2k4mk1 View Post
You probably installed 1 or both head gaskets upside down they are printed with an arrow and frt and if installed incorrectly your car will overheat no matter what as it blocks off the water passage in the rear of the head. Only way to know is pull the heads. I know this from experience. many years ago I did this on my 289 and had this exact issue. Upon install the printing will be up on one side and down on the other.
nope
1 of 472
Old 07-06-2007, 07:35 AM   #22
Jus Workin Away !!!
txlen's Avatar
So this motor isn't in the car anymore??....heck buy the new BOSS 302 block and start from there!!!...thats what ima building !!!
Old 07-06-2007, 10:25 AM   #23
keg65's Avatar
actually want a 427 windsor.
But a budget 289 rebuild, would do for a while
1 of 472
Old 07-06-2007, 07:26 PM   #24
Call around to see if sonic checking a block will reveal casting issues in water jackets. Also I think there is a way to "x-ray" a block.
Old 07-06-2007, 09:19 PM   #25
☆★LSS★☆
Just out of curiousity have you changed the radiator cap? I know the early cars were usually 12 lb I'd recomend going to a 15 lb. That'll raise the boiling point of your coolant........
Old 07-07-2007, 04:13 AM   #26
Mama Mia
68GEETEE's Avatar
might also check to make sure your fan is close enough to the radiator to do its job. If its too far away, it wont pull enough air through the radiator and you will never cool. If you have a fan shroud, your fan blades should be halfway inside the shroud. Mine needed a larger fan spacer to solve this problem, but it did work. Get a feather, and with the car idling, hold the feather near the front of the radiator. If your fan is working you should see the feather being pulled toward the radiator. Try revving the motor to see if it has any effect. If not, your fan is too far away or too small, or you need a shroud.
Also, is the block bored over? If it is bored too much, ie .0060 the block could be too thin to disipate heat. Lastly, as mentioned earlier, check your head gaskets, the water passages should be blocked in front and open at the rear of the gasket, otherwise you wont cool.
Old 07-07-2007, 07:00 AM   #27
keg65's Avatar
checked all that stuff
1 of 472
Old 07-08-2007, 12:12 AM   #28
keg65's Avatar
ok forget it
I'll just stick with the 427 windsor
