Old 07-04-2007, 12:04 PM   #1
keg65's Avatar
overheating engine
In my 65 Mustang I used to have a 289. I had a 4 row radiator, electric fan, aluminum water pump, tried all thermostats.
Running on the highway, normal driving, it would run right around 220 degrees.
and occasionally boil over when stopped.
I've been told that there must be a casting problem in the block causing a blockage or flow problems.
Also been told the problem might have been the heads, 69 302, but i don't think so.
Does anyone know if the block could be a problem? I am wondering if I should get rid of the block and start with a fresh one to use the 289 rotating.
Any ideas?
1 of 472
Old 07-04-2007, 12:32 PM   #2
Jus Workin Away !!!
txlen's Avatar
ok..to help ya diagnose it..does it get hot sitting still??...if so then thats a fan/ water pump type of prob or even t-stat, if it gets hot on the road then you have a flow prob, prob radiator or t-stat or such...what i've done on the early cars sometime was make little air dam under the radiator to force the air up thru the rad and see if it changes things.... Len
Old 07-04-2007, 12:49 PM   #3
keg65's Avatar
It was always hot, but when stopped, it would boil over.
All cooling items were new and had been replaced to make sure.
I think now I would run an aluminum radiator and that will keep the temps down, but if there is something wrong with the block casting, then I would rather start with a new block. Thinking thin or thick areas could be a problem in the casting.
Old 07-04-2007, 12:50 PM   #4
thesource's Avatar
Trader Rating: (12)
Man it could be a lot of things . How fresh is the engine and how long has it been doing this ?
Old 07-04-2007, 12:54 PM   #5
thesource's Avatar
Trader Rating: (12)
How quick does it over heat ? Does it run cooler in cooler weather or does it not matter ?
Old 07-04-2007, 01:00 PM   #6
keg65's Avatar
It always done this, no other engine problems
It would take about 10 min to boil over, when stopped in the summer.
In the winter it would run the same 220, but not over heat
1 of 472
Old 07-04-2007, 01:40 PM   #7
Jus Workin Away !!!
txlen's Avatar
my bet is the rad has a flow prob...you could also try what we do on street rods...a FlowCooler water pump it's got a plate on the back of the water pump to increase flow mostly in the lower rpms...and get a high flow t-stat too..
Old 07-04-2007, 02:28 PM   #8
I have a 65 coupe with a 289 auto, a/s and p/s . I had terrible over heating problems. I added a 4 core radiator from national parts depot, stock water pump, universal 3" fan shroud from summit, and the stock thermostat and a flex fan, then switched to an electric. It was a daily driver in Orlando, FL. I had no problems with it. It would stay right in the middle all day in rush hour traffic with the a/c on. Sounds like something more major, possibly internal. I WAS having similar problems before I did all that work, turned out to be a bad head gasket. BTW, is it still running through the heater core?
01stalker is offline   Reply With Quote
Old 07-04-2007, 03:33 PM   #9
thesource's Avatar
Trader Rating: (12)
I'd say the radiator as well or the fan is not enough for it . My 94 Gt was doing the same thing and I even installed a bigger brass radiator but did not help . I went to a Fluidyne and a stock 2 speed electric fan and that solved the problem .
Old 07-04-2007, 05:04 PM   #10
keg65's Avatar
tried both electric and engine fan and at the same time.
had a new 4 row radiator.
No heater or A/C
Tried the head gaskets, they were good.
Heads not cracked
1 of 472
Old 07-04-2007, 06:46 PM   #11
thesource's Avatar
Trader Rating: (12)
Whats the timing at ? I've seen where the engine is too far retarded and made it run hot . Will the car over heat while sitting still before you go drive it ? Or will it stay about normal before driving it ?
Old 07-04-2007, 06:59 PM   #12
keg65's Avatar
I don't remember, but I know it was right, motor ran really strong. Hoss and I both had our coupes at the same time, had it all adjusted right.
Usually overheating would happen when stuck in traffic. Just the always hot, even when driving.
I just remember someone telling me they thought something was wrong with the casting. The motor will need a rebuild, and if it is possible for the casting to be the problem, I would not use the original 289 block.
The engine is now under a tree at Hoss's house, right in front of where the car sat for 4 years. Just think of the budget build, or wait for the extreme 427 build that I really want
Old 07-04-2007, 07:09 PM   #13
thunderchicken's Avatar
I've seen that engine,He was telling me about that one.It's Probably best if you just look for another block,just in case.....
Old 07-04-2007, 07:51 PM   #14
If it's runing through the heater core still and it is clogged that can do it.
Old 07-04-2007, 11:34 PM   #15
Cooling fan is not putting out enough...
Turbofox is offline   Reply With Quote
Old 07-05-2007, 03:28 AM   #16
keg65's Avatar
but even at 60 mph, the engine just wanted to run at 220 degrees. Tried all the different temp thermostats, even tried without, no difference.
Is there anyway to tell if the casting has problems? Ideas??
1 of 472
Old 07-05-2007, 07:34 AM   #17
67stang347's Avatar
Mine also ran on the hot side. The when it got bored 0.30 over the problem even got worse.
67stang347 is offline   Reply With Quote
Old 07-05-2007, 07:42 AM   #18
Jus Workin Away !!!
txlen's Avatar
cooling fan doesn't do anything above say 35-40 mph....
Old 07-05-2007, 07:59 AM   #19
You probably installed 1 or both head gaskets upside down they are printed with an arrow and frt and if installed incorrectly your car will overheat no matter what as it blocks off the water passage in the rear of the head. Only way to know is pull the heads. I know this from experience. many years ago I did this on my 289 and had this exact issue. Upon install the printing will be up on one side and down on the other.
Old 07-05-2007, 07:29 PM   #20
I still think it is a block casting problem. As much as we looked into it and threw parts at it nothing made a difference. It overheated the same no matter what. At the time I wish we had a infared thermometer to measure the temperature difference between the block and the heads and compare both sides of the block as well. There has to be a water jacket inside blocked off.
