Hebrews 11:3
PCM location
Where does ford generally locate thier PCM's. I'm installing a tach if anyone is wondering. Thanks!
P.S. Will I be able to identify the 47th pin or will I need a diagram.
"The Hitman"
are you doing a raptor performance light?
computer is in the passenger kick panel.... you will need the diagram....it is a rats nest of wires under there
Hebrews 11:3
Thanks for the help, but..... I found I can use the signal off the ICM (Ignition Control Module: tan/yellow stripe wire, pin #2). Saaaaweeet! :fruit2: No raptor light just a tach. I don't even know what it is. Fill me in
#4 | |
"The Hitman"
Its a shift light that some of us here have...Lawrence has a good pic of his maybe he will post it http://www.raptorperformance.com/
