Results 1 to 5 of 5
Thread: Potential bad problem
    Dec 2007
    Marion
    I changed a fuel pump out yesterday, found something I had not seen before, a positive fuel pump wire that had shorted out inside the tank. It had obviously shorted out well enough that the wire turned black and the insulation blistered. As high up in the tank as this was, had there been enought oxygen in the tank, it could have been bad. Luckily the ratio of air and fuel vapors inside the tank was not right for ignition, because there was definitely enough heat to ignite the correct ratio of air and fuel vapors.
    LoneStarStangs Addict Regular Member Burnout's Avatar
    Jan 2010
    Longview
    Wow!
    91 Hatch
    Dec 2003
    SanAntonio
    That coulda been real bad
    85GT FACH1 FINISHED
    fox-man Regular Member sticks905.0's Avatar
    Aug 2005
    san antonio tx
    good nothing happened. good find
    Come chase this ass Regular Member machgsxr's Avatar
    Mar 2007
    San Antonio
    Quote Originally Posted by Sonic Blue 85 View Post
    I don't see the problem.
    Put some duct tape around it and it should be good to go.
    03 DSG MACH - TT - Not fast enough
    03 OW MACH - Slower than above
    11 RR GT/CS - Slower than both of the above
    Thanks to Longoria Race Cars
