Old 07-01-2008, 09:05 PM   #1
power lock actuators
How are these removed? I have a bad passenger side actuator and need to replace it.
Thanks
Black 2002 GT Tri-ax shifter, BBK catted x- pipe w/ SLP Louthmouth, 03 Cobra front bumper, 00 Cobra R Hood, s281 wing, ProTurboKit Turbo, Greddy EBC, Tubular A arms and K-member, subframes, MM coilovers, MM CC plates, Bilstein struts, Audi Rs6 Bi-xenon HID retrofitted headlights
427 rwhp, 505 rwtq
Boost_Me is offline   Reply With Quote
Old 07-04-2008, 12:13 AM   #2
Holy crap....
Trader Rating: (16)
Remove the door panel, roll the window up, there is a rivet in the back corner end that secures the actuator in place. Pop the rivet out, unplug the electrical connector, swing the actuator arm off the lock bar and your done. It is easier then it looks, only problem is you need a 1/4 inch rivet and gun to secure it back in place.
Originally Posted by hoss302
Old 07-04-2008, 09:11 AM   #3
Doesn't it connect to the lock assembly? On mine I saw three torx screws. Do different models have screws instead of rivets?
427 rwhp, 505 rwtq
Old 07-04-2008, 05:20 PM   #4
Holy crap....
Trader Rating: (16)
The only thing that connects to the latch is the actuator rod itself. The housing of the actuator sits in the very end corner of the door (close to the opening of the door) with a 1/4" rivet.
I have replaced hundreds of actuators in my career as a tech and had 8 years of that with Ford.
