Old 05-12-2007, 02:17 PM   #1
Jeramey@StrictlyPro.com's Avatar
Prepping Tires? Launching?
How does everyone prep their tires before each run?
Also how does everyone launch? Currently since I break loose even with 315s in the rear I power brake it and get it up to about 1500 and then punch it on green, and it gives me the best launch. Any other ideas?
Jeramey
Strictly Performance
713-910-0111
StrictlyPro.com
Daily Driver - 08 FJ Cruiser 4x4
Weekend Car - 92 S-Trim Fox
Jeramey@StrictlyPro.com is offline   Reply With Quote
Old 05-12-2007, 06:05 PM   #2
4.6stanger's Avatar
so i take that u have an automatic? well sounds right, ive always raced manuals.
Old 06-18-2007, 12:15 PM   #3
oLD sCHooL fOOL
seco's Avatar
I also did my power braking at 1500 with my old 86GT stock auto back in 1998. Being 17 I couldn't afford sticky tires - LOL
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, MAC O/R H, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades...
Old 06-18-2007, 12:19 PM   #4
Bird's Avatar
With street tires or DR's I stage it at 1000 rpm and slowly roll into it on the last yellow, otherwise I just spin. With the Hoosiers, I can stage it up higher and stab it hard (especially now that I got the differential fixed).
Bird
2001 F-150 Lightning - Bassani Exhaust, Hotchkiss TVS suspension, 14# boost, Shreve Performance tuning
93 Ranger Splash - SOHC 4.0, C4, M-112, Auburn 4.10 LS - it's finally running!!!
Bird is offline   Reply With Quote
Old 06-18-2007, 05:31 PM   #5
with an auto without a trans brake, stage shallow, leave on the second yellow from idle. If you have street tires, just avoid the water. you may want to spin them a tad to get off excess rocks, but no burnout is necessary. If you have drag radials, you may have to heat the piss out of them, but it depends on the tire.
Also, for the auto, do your burnout in a specific gear and feather the throttle to stay off the limiter. Never shift or let your auto shift in the burnout.
MIKE
'86 GT:high 12's
Sold
'01 GT:low 11's
for sale
Old 06-18-2007, 06:25 PM   #6
For one..if you wait to see green you waited too long. When you see that last yellow..GO! 9 times out of 10 you will cut a good light and not redlight. I with an auto 02 supercharged GT would do the same..brake it, rev it let off on third and floor it. Was cutting mid 7's in the 8th-Shane
Shane361 is offline   Reply With Quote
Old 06-18-2007, 08:00 PM   #7
Damn this is good information! Thanks guys! Going to try this stuff out when my DRs get here.
Jeramey
713-910-0111
StrictlyPro.com
Old 06-18-2007, 08:37 PM   #8
the wheel goes round
CrewChiefLite's Avatar
Trader Rating: (4)
I saw you're looking into M/T DRs. With your power, very little warmup is needed for those tires. They hooked well on my car with absolutely no burnout and about a 3k launch. Other than that, Mike will have the best advice for you here.
Car
Car
Car
Truck
Old 06-18-2007, 09:11 PM   #9
Bird's Avatar
MT's and Quick times require very little prep, Nitto DR's require getting the heat up, Street tires are just what 86sleeper said - just clean them off.
Bird
Old 06-19-2007, 03:19 AM   #10
'87 LX 'n '95 GT
d4rkpri35t's Avatar
Send a message via AIM to d4rkpri35t Send a message via MSN to d4rkpri35t Send a message via Yahoo to d4rkpri35t
I prep my tires by just bumping it and doing a little spin. Bumping is just to get the water off your tires.
I launch at about 2K and ease into first slamming on it at the top of the gear. I go through gears quick with the 4.10's so easing on it only lasts a second at most.
95 GT 5.0 w/ some bolt-ons, 2" Drop Eibach Suspension, C/C Plates, 17" Steedas
87 LX 306ci Forged w/ bolt-ons, 4.10's, Built T5, Weld Rodlites, BBK Headers, O/R X, Magnaflow Dumps.
d4rkpri35t is offline   Reply With Quote
Old 06-19-2007, 07:27 AM   #11
Sandbagger
TJVineyard's Avatar
I pull the street tires and bolt on slicks when I get to the track.
I use the line lock to do a decent burnout in second gear.
I stage and bring it to 6000-6500 RPM.
I wait for the third yellow and sidestep the clutch.
I hang on.
Probably not much help to you, but you asked!
Seriously, drag radials will make a huge difference. Do not be afraid to air them down and try different pressures. Airing down normal street tires only hurts your traction. Airing down true drag radials usually helps.
TJ
Dyno sheets and trailer queens don't impress me. Timeslips and drivers do!
TJVineyard is offline   Reply With Quote
