Old 09-04-2007, 08:21 AM   #1
4.6stanger's Avatar
pro 5.0 shifter?
hey guys well just got my shifter and wanna put it in and do i have to put my factory small cup like bushing at the end of the pivot on my short shifter, im confused, cuz ive never been told that. any advice on the installation?
Old 09-04-2007, 08:27 AM   #2
VIC
The "Senior" Member
VIC's Avatar
Send a message via AIM to VIC
I know you need to use it on a Tri-Ax, so I assume you need it on the Pro.5.
Does it fit over the ball on the shifter?
If so, place the bushing in the cup on top of the transmission and then put the shifter in place.
Old 09-04-2007, 08:39 AM   #3
yea, it should fit nicely like that..
Old 09-04-2007, 09:17 AM   #4
oLD sCHooL fOOL
seco's Avatar
yes - you need the cup
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, MAC O/R H, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades...
Old 09-04-2007, 09:30 PM   #5
4.6stanger's Avatar
yeah i did it and worked out great thanx guys!
