I'll bring my vid camera. Hopefully were able to get it to go down 410. If your gonna burn it I'm getting your tires. Haha
Tuned By Lethal Performance
Support Your Favorite LSS Forum Here!
http://www.lonestarstangs.com/forum/...ber-20351.html
You gonna need a tune for that switch?
ray and steve when you guys get your cars up you need to come to my house for some beer and jack. then photoshoot, then margaritas at margies, then out looking for rice liek old times
TUNED BY EAST COAST SUPERCHARGINGAMERICAN RACING HEADERS - VARARAM INTAKE - BORLA EXHAUST - 3.42 GEARS
LSS SOTM Coordinator
^oh that sound cool man thanks. lol jk no invite
lol, i mean anyone can come but everyone time we would post up meets the only three that would show up would be use three. so i really dont bother inviting anyone else.
but your more than welcome to join us but you do need to paint your car red first.
theres a lot of blood stains from using the R switch. so count me in! plus margaritas are my one of my favs! so tonight then because rays car is getting fired up or put on fire today. celebration for both. lol
That thing is going to need a tune bad before it will idle... Even drew's car with those cams had some idle issues and it was a 5 speed. But shoot at least it'll be running!
91 SSP Coupe
Built & Tuned by Bell Automotive
Cage & Chassis by Noribilt
almost happened today, we ended up getting stuck running around looking for nonpi fuel rail lines... that we didnt find so we made our own...and hopefully they are gravy.
2001 Chevrolet Corvette
The Vette gets em' Wet, it also handles nice too.
Stupid Autozone for not selling the right oil cap.
Stupid autozone, pep boys, and napa for multiple different items lOL
fusebox not getting power, believe i found the wire that somehow got disconnect out of its connector, hopefully after I connect it somehow, everything fires over, everything gets power except the fuse boxes, can hear the fuel pump, starter etc etc when key turns over.
Also, Ray's car is a lesson into making sure whoever you buy a used car from at least did routine maintenance on it. Just FYI. I'll elaborate more after we get it fired up and driving.
everything is ready for it to be started, except hopefully this one wire, he's picking up some 8gauge wire, larger connectors, and new negative battery terminal cable, on his way over after work, so I can fix this disconnected wire properly. Hopefully this is the problem, if not gonna go back and start checking the starter connections, grounds, etc.
P1260 Theft Detected, Engine Disabled
fucking damn it. I assume this means he needs a tune and have it disabled in the tune.
I hope thats the problem, I dont feel like spending some more hours on top and underneath your car tracing the wiring harness praying I find something not ground or connected. lOL
lol.
getting there
h&r ss springs, kyb shocks&struts, 17x9 and 17x10.5 03 cobras, bbk catted x with borla stingers, sct tune and 3.73's.
Yeah I can't find anything on how else to disable it except through a tune so IDK, i checked and rechecked, and checked again for a missing ground or something and I can't find anything not ground or not connected.
cars electrical issues are being worked out now![]()
it was the ignition switch wiring causing the problem like Steve said
we only had to check and recheck everything else 40 times before that diagnosis made sense![]()
oil galley plugs....were not in the PI Swap article we used...Ray tossed his NPI heads after his stepdad helped him put on the PI ones, where can we find oil galley plugs?
Hope to see you around med center soon...Good luck with the build
Id say contact a couple machine shops if the auto parts stores dont carry um..
85GT FACH1 FINISHED
Well one more kick in the pants for Ray, since noone swapped the front or rear plugs in, I'm pretty sure that the ones on the deck of the heads were not swapped either.
You guys really should have had someone who KNEW what they were doing assist you with this from the sound of this thread!!!!
85GT FACH1 FINISHED
or kept the heads and oil galley plugs, not overlooked or missed that step completely or double checked everything before/after putting the heads on.
nonetheless though I found new oil galley plugs so we will fix our overlooking.
The overlooking part is what I was referring too When I say had someone who knew. meaning they would have been able to help yall avoid the pitfalls.
Glad ya found what ya needed now it just sucks having to re do all that work....
85GT FACH1 FINISHED
gotcha!
On the plus side, after this, we'll be able to swap heads in record time probably LOL.
question on the nightmare...was engine removed to do head swap?
here is why i ask...im no engine guy but had to learn quick for work on my cobra..
when i had to do my heads for valve repair i did it with engine in car...the cam bolts werent tightened and it broke the gear...i had to remove the heads again and send to shop..they did cover all repair bills for thier misstake,,other than my labor...
this time i had to pull engine to look for metal in pan from gear..wow im so glad i did...it would have went boom...the oil screen was almost completly covered from silicone that falls from timing chain cover..ford was in there once for head replacement...than from manual you only put small amounts of silicone and in certain spots,,,
i found junk in the oil cooler also
hope this thing fires up...i recall owing some beer....would be nice to meet
[SIGPIC][/SIGPIC]my stock 03 cobra
damn brotha! something always pops up after progression, hopefully everything comes together rayy.
yeah car fires up, just bathes you in oil LOL
so now for anyone that does a headwap or builds a motor ...oil galley plugs...they may only cost $.55 a piece...but so fkn important.
