Damn the Spurs are good
Question
A girl that i work with drives a 02 malibu and she is overheating. Well I went to take a quick look at her car, and found a oil sludge like material in her coolant reservoir. Now my question is could this be caused by old coolant/antifreeze, or does she have a more serious problem like a cracked block or something along those lines?
Sludge looked and smelled burnt. She has been driving with low coolant for the past 1 1/2 days
![]() JLT RAI,Tri-Ax,Steeda Pullies,3.73's,MAC LT's,Catted X,Aluminum DS,UPR FLSFC's,PP TB,Jody Plenum,Autometer Lunar Guauges |
#2 | |
just do work
shiiittt my malibu did that since i had it. i swear those cars are built like tanks.
on mine when it did that it was the water pump.
![]() 2003 Yamaha YZF600R - http://www.satxriders.com (SAvoltage) 1986 Chevy K10 4x4 "Monster Truck" - http://www.saoffroad.com (Thrasher86) |
Yea, I was about to ask if you pulled the dipstick out and checked it.
'02 Stang GT Just cause you don't understand what's going on ...don't mean it don't make no sense And just cause you don't like it,...don't mean it aint no good And let me tell you something Before you go taking a walk in my world,...you better take a look at the real world Cause this aint no Mr. Rogers Neighborhood Can you say "feel like shit?"Yea maybe sometimes I do feel like shit I aint happy about it, but I'd rather feel like shit than be full of shit! And if I offended you, Oh I'm sorry, But, maybe you needed to be offended But here's my apology and one more thing........Fuck you! Cause you can't bring me down |
#8 | |||
I eated it..
Expensive job too.. 800 bucks to fix at a shop, unless you know people.
#9 | |
Yep. My siste has a slight leak on hers and it'll be that way until she gets rid of the car. Taking 2 minutes to add a few cups of water when doing the oil change is much cheaper than getting it fixed. I'm sure as hell not going to pull it apart. Once you start pulling those things apart you end up with more stuff to replace. Then it's all downhill from there IMO.
1of5k's bia bia
dunno much about Malibus.... but there was an article on mysa.com about engines sludging over. They said that, if it's a car made to use premium gas and you continually use regular gas, the engine temp changes and oil can sludge over. I had a friend's Endeavor engine sludge over. I asked her about the gas and she said she had been using regular instead of the factory-suggested premium
#11 | |
comin' to get ya!
HOLY SHIT ITS JOHN!!!!! ![]()
#12 | ||||
I eated it..
Exactly, you'll fix it, for a fee. My father and my sister have decided that the car isn't worth the fee.
I try not to do repairs to family vehicles if I can avoid it. They can go bad in a hurry.
