Leaving July 3rd for the Army
Question about burnt valve
Ok, so how would a burnt valve or valve's affect an engine?
acceleration, engine temp etc.? |
#2 | |
so I do not have to type it out for you...
My mechanic says me engine has a "burned valve."... — Yahoo! Autos
ah, so thats why my compression is shit other than besides the engine being worn out?
#4 | |
Nice
get it right Cody
HE IS HE PINGPING!!!!
he will never listen will he
![]() LSS MEMBER # 774 JLT RAI,Tri-Ax,Steeda Pullies,3.73's,MAC LT's,BBK Catted H,Aluminum DS,UPR FLSFC's,PP TB,Jody Plenum,Autometer Lunar Guauges |
#9 | |
They make the alternator take a crap...
#10 | |
damn, well, I bet mine probably look a lot worse.
"Valve burning can also be caused by any condition that makes the engine run hot or elevates combustion temperatures. This includes cooling problems, abnormal combustion like detonation or preignition, loss of exhaust gas recirculation (EGR), retarded ignition timing or lean fuel mixtures." I wish I would have read this sooner, thats why she's been overheating too, and would of course explain the "pop!" sound it makes sometimes when I give it gas. Quote:
But when I'm gone, I'm going to have the engine completely machined and bored over .20, I wanted to go .30 but my dad suggested the block would be no good if I ever needed to get it machined again, the walls would be to thin, and it would run hot. I'm going to have a complete forged bottom end dropped in;crank, connect rods, etc. , which Jody or someone who knows about pushrod motors, I can't find a forged 289 crank, but they have a 302 crank that has a 3.00'' stroke to it, and I was wondering if its a 289 crank listed as a 302? Once I get the block machined, find a nice hydraulic roller cam(if possible to put in the 289) and some gt-40p heads with some roller rockers on them. And later on, a paxton s/c like they had on the gt.350's |
#11 | |
Coming to a 17" rim near you
ok so instead of getting a ready built motor because ur too lazy to get up off ur ass and go get it... ur gonna spend more money getting ur shit machined.... not a very wise allocation of your money but what do i know. |
Why not when you are gone just save your money buy a brand new engine and give that bitch some balls....just my .02
#13 | |
If you read all the way, I had reasons; the motor would just be collecting dust and I'll build my 289 the exact way I want it and have a forged bottom end block I can s/c and also rev higher than a non-forged block. I'd rather spend some money and have a better engine in the long run. Just my .02 |
#14 | |
I'll say it again.
GO BUY A GT40P Longblock! do you really not factor in such things as the cost of gas to drive your heads to a machine shop and the cost of your time? rarely does your price come out as the original quote after they find problems when the heads are apart.
#17 | |
But, once I find a nice cam I'll either get gt-40p heads or some afr heads, and most likely new, I don't want to mess with used heads. ![]() |
#18 |
wtf is a forged upper?
I get it so you are going to make your dad front the gas and his time and money. I dont think there is such a thing as a new gt40p head.... what do you mean find a nice cam? you should buy a cam when you know what heads and intake you will run, not vice versa. Cam is the final decision based off knowing what the other "flowing parts" need
2007 Reflex Silver Wolfsburg Jetta - new hotness 1995 Canary Yellow GTS - Sold 12.81@106.2 w/1.80 60' Boltons/E303 + 3100 lbs + M&H 246 HP/ 290 TQ 12.57 @ 109.21 w/1.76 60' Boltons/GT40Ps/XE270 + 3240 lbs + 555Rs 295 HP / 321 TQ Last edited by 95 GTS; 06-19-2008 at 03:55 PM. |
#19 | |
Get It?
feel free to review, your just wasting your breathe Fustrating |
#20 |
ok that was harsh, but you are so damn frustrating
