Results 1 to 8 of 8
Thread: Questions on motor swap?????
    Regular Regular Member mando99's Avatar
    Mar 2008
    lufkin,tx 75904
    well i got a 65 mustang coupe that had a straight 6 took it out and redid the engine compartment and a friend of mine is selling me a 95-96 gt mustang complete car that has been wrecked but engine and trans. still good just wondering how hard will it be to put that set up in my 65 ???? any imput would be awsome
    Joe Wilson 2013 Regular Member Stang6uy's Avatar
    Mar 2005
    San Antonio TX
    pretty simple as far as swaps go.......just google it....there are tons of write ups on this swap,....GL...
    1983 GLX Blu-sold
    1989 Blk coupe-sold
    1990 Blu hatch-crushed
    1993 white vert-sold
    1985 gt hatch white-sold
    1990 Blk coupe-sold
    1990 Blk coupe-sold
    1990 red hatch-sold
    1995 yellow gt-sold
    1996 Blk gt-sold
    2000 Blk gt- gave to brother
    1990 Lincoln LSC-sold
    1991 white LX hatch-sold
    1989 white Shelby dakota #147-sold
    1993 Red Lightning #3395
    Mr. Anti-Bling Regular Member Deviousfred's Avatar
    May 2010
    El Paso, TX
    Well, first and foremost, you need to find out if it is a 95 or a 96 because those are two totally different motors. Both can be swapped in but one will require far more work than the other.
    If it is a 95, then it is a very straight forward swap. New motor mounts and trans crossmember and you're pretty much set.
    If its a 96, then you will need a Mustang II style front end that eliminates the shock towers.
    First see what it is so you know what you're getting into.
    __/___________\__
    O[[[_________]]]O
    l__\o---------o/__l
    '65 Coupe
    '81 Hatchback
    whoa pony!!! Regular Member keg65's Avatar
    May 2005
    NE San Antonio
    depends if its a small block 5.0 or a mod 4.6
    2012 Mustang GT
    5.0, 6 speed, Brembo package
    Barton short throw shifter, Magnaflow Competition Exhaust, JLT carbon fiber CAI, SCT X3, UPR uca and lca, JLT oil separator.
    Dec 2003
    SanAntonio
    If its a 5.0 pretty simple deal. Need correct oil pan for early car and motor mounts that will get the motor in the car. Ditch the efi intake and dizzy and go with a carb set up will save alot of work/wiring. You can go EFI if you are willing to spend teh effort/money needed.
    If it is a 96 car with a 4.6 as said above that is another kettle of fish and alot more involved.
    85GT FACH1 FINISHED
  6. #6
    Jun 2003
    Trashcanistan
    The motor mount brackets need to be changed. Suspension and steeering linkage is different as well. Also the rear end is a spicer that will not hold up to a v8 very long.
  7. #7
    May 2008
    id go with a carb set up as well. Pull off the efi manifold and bolt on a carb set up. Youll need to get 65-66 mustang v8 motor mounts. You need to also get a front sump oil pan and oil pump. The oil dipstick needs to be drilled in the front timing chain cover. You will need v8 headers and a different distributor with a roller cam gear. You will learn as you go. Its nothing major but just a bunch of little things like so.
  8. #8
    Mar 2008
    lufkin,tx 75904
    thanks on imput its a complete car so i might go with efi its a 95 cuz got a 302 in it googled it and found alot of good info on how to do so everyone wish me luck lol
