Old 02-17-2008, 11:42 AM   #1
67fstbck
rear disc
Does anyone know if the Lincoln versailles rear disc mounting plates will bolt right up to my 1967 9"?
67fstbck is offline   Reply With Quote
Old 02-17-2008, 01:09 PM   #2
Here is a little info I found in about 30 secs on the web
Lincoln Mk VII Rear Disc Brake Conversion for Early Mustang & Ford (8- & 9-inch Rear Ends)
Old 02-17-2008, 04:51 PM   #3
67fstbck
rear disc
Thanks for the link. Now I have another question. Does anyone know the differences between the Versailles and the Mark VIII?
Old 02-17-2008, 11:21 PM   #4
Check ya later!
There is alot of things that are specific to the Versailles rear end that will not interchange between other 9 inch rear ends. Why not swap a complete Versailles rear end? You can even use the factory mustang brake cables. I have a Versailles in my 66 coupe.
Old 02-18-2008, 09:00 AM   #5
67fstbck
rear disc
Availability. I found someone selling just the rear disc setup not the entire rear-end.
