Go Back   Lone Star Stangs | The Texas Mustang Club > Mustang Tech Forums > General Mustang Tech
General Mustang Tech General Mustang-related questions
Old 11-22-2008, 04:38 PM   #1
Is that a mach?
y2kGT's Avatar
rear end question
i have moser 31 splines and cobra diff and on my driver side axle in my 2000 gt and it seems to have about an eigth of an inch of play. The passenger side has none! This little bit of play is making my rotors rub on my caliper bracket. Any ideas? C clips bad? Any help is appreciated!
Y2kGT-Just another 4-6
1995GTVERT-DD
1989LXVERT-waiting to be reborn!
y2kGT is offline   Reply With Quote
Old 11-22-2008, 06:45 PM   #2
Sonic Blue 85's Avatar
Could be a C clip, cross pin, axle or worn clutches.
Old 11-22-2008, 08:19 PM   #3
Is that a mach?
y2kGT's Avatar
well they are brand new axles. The diff has low miles. I think it my be a c clip cause it was recently wrecked and it bent an axle. when i pulled them out they looked ok though. the cross pin seemed fine.
1995GTVERT-DD
Old 11-22-2008, 08:49 PM   #4
Only thing I can think of is that the groove for the c clip may be mis machined meaning the groove is too large.
Old 11-22-2008, 10:31 PM   #5
Is that a mach?
y2kGT's Avatar
i already had those c clips on my car before though and never had a problem. the only thing that changed was newer axles and a wreck? im going to tear into it tomorrow and check the pin and c clips. any leads on things i should look for in specific?
1995GTVERT-DD
Old 11-23-2008, 11:32 AM   #6
just pull the axle out and put the c-clip on it outside the car to see if it's loose, should be snug but not too tight.. as in shouldn't have 1/2 inch of play or anything.. also check the cross pin for wear, if you need one, holler at me, could ups a used one to you for just shipping cost
Old 11-23-2008, 12:11 PM   #7
Is that a mach?
y2kGT's Avatar
cool im about to tear into it right now.
1995GTVERT-DD
Old 11-26-2008, 12:28 PM   #8
Authorized HATE™ Dealer
SUfanINsa's Avatar
So what was wrong?
"THIS IS THE INTERNET, IF YOU CANT HANDLE IT GTFO" LOBRA JUST LEFT.
Old 11-26-2008, 05:36 PM   #9
Is that a mach?
y2kGT's Avatar
one axle was a little bit too long. totally gey!
1995GTVERT-DD
Old 12-03-2008, 12:42 AM   #10
I had the same type problem with mine, except mine was on the passenger side.
blackedout01gt is offline   Reply With Quote
