Old 08-04-2008, 09:33 PM   #1
Send a message via Yahoo to X2CRAYZIX
Rear main seal
How hard is it to replace the rear main seal and do you have to have a special tool for it?
X2CRAYZIX is offline   Reply With Quote
Old 08-04-2008, 10:34 PM   #2
whitey92lx's Avatar
well other than having to pull the exhaust, transmission, sometimes headers, driveshaft, starter,clutch, and flywheel, yoou can usually get it out with a small screwdriver.. then push the new one back in... not sure if this is the way the pros do it, but it works... good luck.
http://westsidemustangs.com
whitey92lx is offline   Reply With Quote
Old 08-04-2008, 11:23 PM   #3
I am going to be replacing my tranny in the next couple weeks and figured while it was out id replace the rear main seal
Old 08-05-2008, 12:06 AM   #4
marunos's Avatar
Send a message via MSN to marunos
Hey, do it well and safe! it's always better to pull the transmission and have have the seal installed. I had done that to my car. Now, it's perfect.
marunos is offline   Reply With Quote
Old 08-05-2008, 07:28 AM   #5
Oh shiy Cris I PMd ya back but disregard I was confused I was thinking of the rearend seal not the :rearmain: as in crank. I was confused..........
It is still doable however.
Old 08-05-2008, 08:30 AM   #6
Box Foxes Rule!!!
racer99's Avatar
If you have the trans out,it is crazy not to do it.
of stupidity!
78 Zephyr,
82 Granada Wagon,
88 Mustang 2.3T
94 GT
Old 08-05-2008, 09:51 AM   #7
Im gonna have to as it seems to be leaking
Old 08-05-2008, 11:32 AM   #8
4.6stanger's Avatar
Real easy to do, almost the same method as installin axle seals.
What will it be, Breakin 12's or Breakin drivetrain.
Old 08-05-2008, 12:00 PM   #9
purchased a new seal an hour ago
Old 08-05-2008, 03:59 PM   #10
Craiger
I have replaced a clutch years ago when I first started to wrench and did not replace the rear seal. I ended up losing oil all the time and eventually did the job again only to do it right the second time and replace the seal. A small screw driver or a seal puller (specialty tool) will do the trick. The new one should go in pretty easy. You might have to tap it in gently to make a perfect fit. Just dont use a screw driver to tap it back in. LOL.
1989 GT Convert. 5.0
craiger is offline   Reply With Quote
Old 08-05-2008, 05:01 PM   #11
Thanks for the info guys ..
Old 08-14-2008, 04:47 PM   #12
lilbluehatch's Avatar
i think auto zone has a specialty tool called a sneaky pete you can loan i herd it works
lilbluehatch is offline   Reply With Quote
