Old 06-07-2007, 05:53 PM   #1
93Stanglx's Avatar
Send a message via AIM to 93Stanglx
rear speaker help
aiht guys the other day i connected my rear speakrs onto a 200watt amp but now when im driving the car i hear like a "whistling" sound the faster i go the louder the sound gets even if i take away the ground cable from the amp i can still hear it.
So i assume that its coming from bedhing the deck? what should i check? do?
1993 LX converted to GT :jeff:
93Stanglx is offline   Reply With Quote
Old 06-07-2007, 07:35 PM   #2
put a ground loop isolator inline w/ the rca's... i have one.. pm me if you like
1991 lx coupe
Old 06-08-2007, 06:50 AM   #3
John#21's Avatar
that will work But...
You should try regrounding the radio and the amp first.
Thats "alternator noise" and is usually caused by a bad ground. The isolator really should be a last resort as most whine can be eliminated by providing a better ground.
Make sure its clean. No paint or rust. Also make sure its short. Try not to run the ground more than a few inches.
If that doesn't work get the isolater. and if that still doesn't work, i can send you a link to a more remote possibility. Its really 1 in a million otherwise I'd post it now.
GO SPURS GO
