Old 05-28-2007, 08:15 PM   #1
Reliable HP/Torque Through 5.0
How much reliable/streetable HP/Torque can be run through a stock 5.0 block with stock rods, pistons, and crank? What if you added a stud girdle to help support the bottom end?
Thanks,
Rob
rlauer is offline   Reply With Quote
Old 05-28-2007, 08:40 PM   #2
depends on the year.. i'm assuming u mean a 5.0 ho.. roller?
1991 lx coupe
Old 05-28-2007, 08:55 PM   #3
It is out of a 1994.
Thanks,
Old 05-29-2007, 09:06 AM   #4
Box Foxes Rule!!!
racer99's Avatar
General consensus is 525 to 550 hp with a safe tune.
This is with forged pistons.The later hyperteutectic
pistons not quite as much.
Some have gone 600 but its on borrowed time.
A stud girdle just keeps the parts in a nice pile
when it lets go.
The roller is the weakest of the Windsor blocks.
of stupidity!
78 Zephyr,
82 Granada Wagon,
88 Mustang 2.3T
94 GT
Old 05-29-2007, 10:18 AM   #5
thesource's Avatar
Trader Rating: (13)
Safely ??? I'd say 400 hp on that year engine with a good tune although there are several people running much higher than that .
I had a customer crack a roller block with a N/A 347 in less than 2 weeks . The engine was maybe making 400 at the flywheel and it was built by Janke engines here in San Antonio .
Old 05-29-2007, 10:58 PM   #6
thunderchicken's Avatar
Did they abuse it to make that happen?
Old 05-29-2007, 11:33 PM   #7
CraZy6's Avatar
I think Mike Murillo will only tune 500hp on a stock block. SO 500hp is possible, but to say how long it will last, just depends on hard you ride it.
CraZy6 is offline   Reply With Quote
Old 05-29-2007, 11:55 PM   #8
you smell that?!
311-420's Avatar
couple guys on here making around 500 at the wheels with stock rotating assemblies. if you get it tuned and the air/fuel is safe, your pistons should stay intact as long as you dont over-spin the engine.
04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
Old 05-30-2007, 06:26 PM   #9
thesource's Avatar
Trader Rating: (13)
I'm not too sure what the hell happened with it . I almost think the block might have been damaged before it was used to build the 347 but would think they would have caught that over at Janke's when building it ........
Old 05-31-2007, 11:21 PM   #10
Lifted78Chevy's Avatar
from what i've read , 500 range is about max on a stock block, but like it goes you abuse it, it will break no matter what motor it is, so alot of it depends on your driven style and how hard you get on it, if u drop a ton os NOS on the car or tooooo much boost with not enough fuel your gonna have some problems sooner or later, so when u build it make sure you get all the right piece's working together and air fuel ratio right and don't over rev the motor and u should be good to go.
1989 LX Coupe 5.0
Tuned at PSI.pulled threw 5800 no stop shut it down at 6 grand....
Next motor all out with it...hope make 6-7 hundred hp
Old 06-02-2007, 04:26 AM   #11
'87 LX 'n '95 GT
d4rkpri35t's Avatar
Send a message via AIM to d4rkpri35t Send a message via MSN to d4rkpri35t Send a message via Yahoo to d4rkpri35t
an old friend of mine pushed his to about 625 before he fuked the block up.. this was bored and stroked 331...
95 GT 5.0 w/ some bolt-ons, 2" Drop Eibach Suspension, C/C Plates, 17" Steedas
87 LX 306ci Forged w/ bolt-ons, 4.10's, Built T5, Weld Rodlites, BBK Headers, O/R X, Magnaflow Dumps.
d4rkpri35t is offline   Reply With Quote
Old 06-02-2007, 03:31 PM   #12
Yup that true....Jenke's is very reputable.I knew a friend that had is race engines built there..
Old 06-03-2007, 11:45 AM   #13
The stock block can take reliably 400 - 450 rwhp as long as you dont detonate it.
anything over that detonation or not your rollign the dice..
and main girldes do NOTHING for them as far as stoping the block cracking .. since they dont crack in the mains to start with the cracks start in the thin lifter valley when work there way DOWN to the mains not vice versa.
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 06-03-2007, 01:35 PM   #14
That makes sense...
Old 06-05-2007, 05:00 PM   #15
I agree 100 percent
94 has hyper pistons so you are limited in that respect as compared to the 92 and earlier with trw forged. Now this is with stock rotating assembly.
a turbo application will be able to hold more than a supercharger application, as will a nitrous (if tuned correctly) It doesnt have the power strain and the sideways tension on the crank snout that a supercharger creates. SC takes power to make power.
Chris' cobra made 524 on stock longblock with an hp turbo kit. then 570s with heads and a victor 5.0 intake. Thats with non forged pistons and a great tune!.
Jeremy's coupe with the TRWs made 565/640 on the giggle gas with a HCI setup.
what should you daily drive safely?
SC 400-450 and a wee more with a turbo. Plus the turbo you can turn down for longevity.
