George
removing cd player "help"
does anybody know how to remove a cd player from a mustang year 2000 it wont let me pull it out
![]() 2000 LAZER RED SALEEN #0263 373s, 70MM throotle body ,port and polished intake, bassani x pipe, 3''magnaflow tips, mac cold air ,100 shot of nitrous 7'' keenwood flip out screen two 10'' JL audio subs with jensen amp |
LoneStarStangs Addict
Did you press in the clips that hold it down through the four holes on the face of your deck?
![]() Quote of the Month- "F**k if you understand me, I love being misunderstood, cause I live in suburbs, but I come from the hood" -Lil Wayne Impossible Maze Game<<< Really a maze game, not the song anymore |
get some nails and push them in the lttle holes to release the clips, then it will pull right out (thats how it was on my f150, i dont remember too much about my factory radio, it wasnt in long lol)
George
ok il try that right now
#5 | |
re re
Or get a coat hanger and cut it, bend it in a loop and slip them in the 2 holes on each side. They actually make a tool and I think Wal Mart carries them for under 6 bucks I think...
werd, they work like a charm. usually have to push them in, and then pull them outwards - towards the doors, and it should slide right out.
George
il try the coat hangers and see my results
Did you get it?
George
yea i got it it came out really easy i have a screen on my car so i dont use the cd player no more so i decided to take it out
your saleen is a 2000? damn i was gonna try to buy that factory head unit off of you, but i believe mines different.
George
yea i think it is different
or didnt the radios change on 2003s and up
oLD sCHooL fOOL
so I'll probably get some pictures posted - I'm have a cd head unit I would like to install. I obviously plan on removing the tape deck and cd player from my 1999GT. Problem is when I pulled out the tape deck - I was unfamiliar with decoding the power - ground - speaker wires. Have no idea which wires are what. Maybe with pictures and a list of wire colors I see, someone can help determine which is which.
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, UPR O/R X, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades... ![]()
