07 Mustang GT
removing the mufflers
Just thinking about removing the mufflers on my 07 GT to see how it will sound with out them, will this cause any problems or give me a CEL?
Is it possible to just remove the mufflers from the axle back, then just leave it like that for a few days or will that harm something? sounds good or not? will I loose allot of hp and torque or not really? |
#2 | |
I loved how it sounded. . . good and deep, but the pipes that connect the h-pipe to the mufflers have no other support than where they clamp on to the h-pipe. As long as you don't plan on doing too much driving in the next few days, it won't be a problem. When you hit a bump, or a speed bump, the clanking sound you're going to hear is you pipes hitting the axel. |
i would unbolt it at the back of the h pipe... trust me, you dont want anything more than like 8 inches of un supported exhaust... caused lots of problems in a vehicle i used to have..
t-5 swap, billit quadrant, upr firewall adjuster, steeda tri-ax, custom jb tool and fab one off subframe connectors. coming soon: 8.8 w/ 3.55:1's, '00 gt brakes, followed by my 306 swap |
CEL?... what is that,,?
#5 | |
Check Engine Light
2007 Mustang GT
Funny that i see this post, i just disconnected mine yesterday at stangalang's apartment. I just took off the mufflers and it was loud as hell, it sounded good at idle but once i was cruising down the road it sound like crap unless i WOT. We put them back on today because i could not handle the noise man it was crazy.
Magnaflow mufflers, O/R X-pipe, JLT Cold air Intake, Diablosport predator tuner, Steeda Pullies, Motion Delete Plates, Bamachip 93 race tune, Hurst Competition/Plus shifter http://www.myspace.com/Bigtravh |
4 valve FTW
yeah - w/out the mufflers it's like getting that loud as hell back-fire fart sound - LOL glad you put them back on
SLP loud mouth cat-back, Pro 5.0 short throw, 4.30 gears, Steeda sport springs, chrome 18x9 18x10 Saleens, NT555's 285/40/18 rear, and an O/R X and RAM clutch soon to come..... ![]()
but is the rest of your exhaust stock? travis' (rowdyjohnny) car doesn't have cats...
It is a very easy de-install/re-install with minimal hand tools. I do agree that axle back pipes may need to be supported.
As for the sound it produces...to each his own!
'07 GT/CS Eibach drop, SCT, CAI, OR/H pype, UDP, Blah, Blah, Blah! |
