Old 09-12-2003, 02:21 PM   #1
Replacing HUB bearings
Has anyone done this to thier sn95 mustang? I hit a curb and my car passenger tire went way out of wack. Had to pay $300 yesterday to Northside ford to get a inner tie rod socket replaced,alignment, and rebalance a tire. The rim looks to be bent because it still shakes, but last night i went into an empty lot and did a slow circle. When circling right --all good no problems. Circle left and there is a LOUD popping and when it pops the car will actually rock to the right???? Any ideas. Is this a tie rod (sterring issue) or maybe a hub bearing. I really appreciate the help. I am in the dark and am thinkin i got taken for $300.
MODS:
Cobra body kit,98 COBRA 32V Engine,C&L inlet pipe,BBK single blade T/B, Walboro 255 fuel pump, MAC O/R X-pipe,MAC Catback, Steeda x2 Balljoints, Tokiko shocks & Struts,Bullit Shifter & Pedals, FRPP Gears, Cobra Brake Conversion,2003 Cobra Rims,FRPP underdrive pullies, UPR caster/camber plates
98stangman is offline   Reply With Quote
Old 09-12-2003, 06:37 PM   #2
Sounds like something loose or possibly still bent.Bearing will make a growling noise when bad not a pop.Check out where the strut mounts to the spindle those bolts may be loose.
