STILL SMOKE FREE SINCE 4-28 10PM!
Roach sound upgrade
Here are some pics of the sound system upgrade in the roach....thanx to the hook up from Dynamic sounds by Timmah.....thanks to james at dynamic sounds....
I used my existing Rodek amp from the avenger and replaced the stock ford speakers with Crewin vegas...and two 12 inch rockford "Punch" subs.....cost $650 and change.
AWARD WINNING 2005 Roush Stage 2 HURST PRO COMP SHIFTER, FORD RACING HANDLING PACK, WHIPPLE-FORD RACING 11 PSI HO SUPERCHARGER, FORD RACING 3.73 GEARS, FORD RACING TUNE, FORD GT 38LB/HR FUEL INJECTORS, SHELBY GT-500 FUEL PUMP, 95MM MASS AIR FLOW METER, TRUE COLD AIR INTAKE/ 9" S&B TRUE-FLOW FILTER, 0 DEGREE FORD RACING SPARK PLUGS, FLUIDYNE OVERSIZED HEAT EXCHANGER, 5" ALUMINUM INTERCOOLER, ROUSH LEATHER SEAT UPGRADE, PAINTED STRIPES. Max Power 457.70 ![]() Max Torque 433.14 ![]()
pics............
Sounds better than 15's in the avenger....I still have the other amp from the avenger and both 15's..dont know what I'll do with em...unless someone wants em cheap...the 15's are Orion's
post em in the classifieds, maybe some one will bite
When I first saw this post I though you had gotten a new exhaust.
GO SPURS GO
yeah....it sounds a hell of a lot better than the stock crap ford had in there....i 'm still debating on keepin the stock stereo...I am for now..
Yes he is...hooked me right up..did top notch work quick...!
☆★sSs★☆
have you tried fliping the box around (speakers facing the trunk).
i have almost the same setup. and once i did that the trunk used itself as box and gives you a better/louder sound.
06' Tungsten Grey GT |
Hates Liberal Scum
glad i could help you out....well at least send you over to james. i wanna hear it friday
you will..I b there..
