Old 02-26-2008, 11:53 PM   #1
Roller Block??
Is there some numbers on the block that will tell me what year my block is and if it's a roller block or not?? If so where are they located and how can I tell?? Thanks for the help. I know ive been asking a lot of beginer questions but im new to ford...
Razor81 is offline   Reply With Quote
Old 02-26-2008, 11:58 PM   #2
there are some casting numbers near the starter.That Should tell you when the block was made which can be a pretty good indication whether it's roller or not.....
Old 02-27-2008, 12:16 AM   #3
Do you have the book or something to tell from the numbers or how would I do that once I have the numbers of the block near the starter???
Old 02-27-2008, 07:05 AM   #4
UT Sucks
The fastest way to tell if it is a roller block is by the bosses in the lifter valley being drilled and tapped. This is where the "spider" is bolted down to retain the roller lifters. A simple internet search will give you several sites that have the block number listings such as:
FORD BLOCK CAR CODES
Darren
Old 02-27-2008, 08:45 AM   #5
Darren
Thanks Darren
