Old 05-13-2008, 05:08 PM   #1
Leaving July 3rd for the Army
Ryan_65Stallion's Avatar
Question Rough idle, and wants to die...
Ok, so I got my new setup on. and it was running fine the other day besides a little rough idle.
Here's the problem, when I start it, it won't want to stay idling, and I'll give it gas and it'll rev up fine. So I adjusted the idle screw and kicked it up, turned it on again and it idles a little high in park, but once I put it in drive it wants to die unless I give it gas.
Could it be the timing? because it is also getting hot. and fluid is good, hoses aren't blocked, t-stat is good. what could it be?
1965 Mustang
Old 05-13-2008, 05:14 PM   #2
HE IS HE PINGPING!!!!
SUfanINsa's Avatar
Trader Rating: (3)
yes it could be the timing, but check your alternator!!!!!lol
LSS MEMBER # 774 JLT RAI,Tri-Ax,Steeda Pullies,3.73's,MAC LT's,BBK Catted H,Aluminum DS,UPR FLSFC's,PP TB,Jody Plenum,Autometer Lunar Guauges
Old 05-13-2008, 06:14 PM   #3
fuck you
1965 Mustang
Old 05-13-2008, 06:18 PM   #4
LoneStarStangs Addict
Wiked's Avatar
I had that problem with my new edge, but not sure they would even be related, my EGR solenoid was causing my car to lunge, and the IAC was causing the idle to mess up
Quote of the Month- If all of you had a chance to have a 1967 GT500 clone you would jump on it, and dont say you wouldnt. I have honestly started realizing lately that most of us on this web site are a bunch of hating ass hypocrites. I my self would like to change my ways, why not join me? - Me
Wiked is offline   Reply With Quote
Old 05-13-2008, 06:38 PM   #5
65 Mustang Tune Up Specs
This is a page I found.
Now, what does "dwell" mean? and how would I adjust it?
1965 Mustang
Old 05-13-2008, 06:52 PM   #6
Evil Angel
Bigdrumma22's Avatar
Definitely recheck timing and the electric choke if you have it. Make sure you have the high idle speed set to a reasonable RPM (usually have to open the throttle all the way with car off to access the adjusting screw). The normal idle screw (easy access one) should only be messed with once it's up to temperature because that's where it will idle while at a light, etc. I'm not carb master by any means, but I have some experience on my truck. I used to have a Holley on there, but I couldn't keep the thing tuned right myself. I switched to Edelbrock a few months ago, bolt on and go. Haven't had any problems so far.
Old 05-13-2008, 06:57 PM   #7
Dwell is another name for piont gap.
Since it is a cold issue does it have an elec or heated choke?
If elec did you hook it up?
If heated does it have the riser tube to warm the spring and open the choke?
I can ck it out if ya wanta bring it by.
Any evening after 530 or so is OK just LMK.
Old 05-13-2008, 10:52 PM   #8
2001 Oxford White Mustang GT
aguilarf's Avatar
Trader Rating: (9)
First of all check for vacuum leaks or any unplugged or cracked vacuum hoses on the intake manifold, carb, and dist. Make sure the dist vac line is not plugged into the constant vacuum source on the carb.
Dwell is different from the point gap. Dwell is usually best set with a dwell meter.
The dwell angle is the number of degrees of distributor cam rotation through which the breaker points remain fully closed (conducting electricity). Increasing the point gap decreases the dwell, while decreasing the point gap increases the dwell. Dwell angle should always be checked after adjusting or installing new points.
The link below explains it pretty well, except that it's on a 31 6 cyl. chevy. Ryan in your case the distributor lobe would be octagonal.
Points Gap - Dwell
rough-idle-and-wants-to-die-493b_1.jpg  rough-idle-and-wants-to-die-dwell24.jpg
aguilarf is online now   Reply With Quote
Old 05-13-2008, 11:37 PM   #9
Trader Rating: (20)
Installation error or a bad kanuter valve !!
Old 05-14-2008, 12:26 AM   #10
keg65's Avatar
He probably just didn't connect something right!!
1 of 472
Old 05-14-2008, 06:27 AM   #11
True dwell is best kd with a meter but in essence you are setting the same thing the piont gap. You did a nice job explaining it however.
