Go Back   Lone Star Stangs | The Texas Mustang Club > Mustang Tech Forums > General Mustang Tech
General Mustang Tech General Mustang-related questions
Old 11-07-2004, 03:09 PM   #1
Its all about Jacob and Daphne!
foxracermenace's Avatar
Send a message via AIM to foxracermenace Send a message via MSN to foxracermenace Send a message via Yahoo to foxracermenace
royal purple purple ice
is it any good.
what about oil stabalizers?
foxracermenace is offline   Reply With Quote
Old 11-07-2004, 09:02 PM   #2
Mama Mia
68GEETEE's Avatar
I would only use additives if you have an existing engine problem. I used Red Line Water Wetter and it did help my engine run cooler. An oil stabilizer really shouldnt be necessary in a tight motor with good oil pressure. May help a worn engine some.
Old 11-07-2004, 10:34 PM   #3
thanx i just want to help my 04 run better you know
Old 11-29-2004, 09:28 PM   #4
try royal purple oil i ran the same water cooler but only worked for a while...........what do you mean by run better, try
lincolnboy is offline   Reply With Quote
Old 11-29-2004, 09:28 PM   #5
what you got a 2v or 4v,
Old 11-30-2004, 01:44 AM   #6
Putting purple ice in the car (2003) on Thursday along with 180* thermostat. I'll let you know how it goes.
sleeprinsa is offline   Reply With Quote
Old 11-30-2004, 06:26 PM   #7
alright thanx much
Old 12-06-2004, 09:45 PM   #8
purple ice
GET IT!!!!!! Its worth the $10, you should change you thermostat to an 180* while your at it. Its only $5.99 at pep boys. My temp is now below the midpoint. Before it was slightly to the right. This combo will reduce detention and since your engine is cooler you'll pick up 1 maybe 2 horses. Its easy to install and definately worth $16. In case you're still unclear, GET IT!!!!!!!
