Hello, so this is a stock 1988 5.0, manual, no MODs. When I switch off the AC , the RPM goes all the way down and the car goes off !! Any suggestions what this could be? any emission mess up ?
________
LIFE INSURANCE FORUMS
________
Yes the idle is fine with the AC on! when the AC is off idle is at about 700.. and when it's on it's at about 800..
________
YAMAHA YZ450F
could his crank case filter be clogged?but if it was the car would stall or shut off.????????
Possibly a dirty IAC and throttle body, could also have oil in both as a result of a PCV system problem, like mentioned above.
how would IAC or TB get oil?? how to find out and fix?
________
Strain Index
The screen below the PCV vavle has to be plugged up, missing, missing baffle, below the screen, plugged or disconnected crank case vent hose or PCV hose. I see people try to cap off one or the other or leave one disconnected and then have the other still hooked up, does not work anyway other than both hoses hooked up, baffles in place, screen in place and not plugged up with sludge. The screens are only about $150 at Ford dealer and are fairly easy to replace, but most people will never replace them, if they get plugged oil will get pushed up the crank case vent hose to the throttle body. If the screen is missing or the baffle below it is missing, oil will get sucked up through the PCV valve into the intake, filling the intake with oil. Putting breather on the valve cover with eithe the crank case vent hose or the PCV still hooked up allows the engine to draw in unmetered air, meaning air that is not going through the MAF, meaning the engine will run leaner, because air got into the engine and was not metered by the MAF. Either leave the whole PCV system on the engine and functioning properly or cap all of it and use a breather or two, using two breathers is better.
my 01 is doing the same thing it is etheir a vacum issue or a egr valve is what i was told
i will let u know monday when i am off and can fix the damn thing
here it is
