Results 1 to 9 of 9
Thread: Running hotter after coolant flush
    There's always something..... fresh fish! Rewind351's Avatar
    Sep 2005
    Cypress, TX
    Hey guys,
    I flushed the radiator and replaced with a 50/50 mix and the car seems to be running hotter than before. Seems to run between 210 and 220 degrees. I burped the system and tried everything I could think of. The fan kicks on at 218 degrees and off at 210 degrees according to my autometer gauge. I thought the stock points were 221 and 200? Any ideas what I could do besides upgrading the radiator? Also, the car usually would run around 190 degrees before the flush. I've had a 180 thermostat in it for a couple years.
    Thanks,
    RWD
    whoa pony!!! Regular Member keg65's Avatar
    May 2005
    NE San Antonio
    maybe you damage thermostat.
    Might try to replace it.
    2012 Mustang GT
    5.0, 6 speed, Brembo package
    Barton short throw shifter, Magnaflow Competition Exhaust, JLT carbon fiber CAI, SCT X3, UPR uca and lca, JLT oil separator.
    Sep 2005
    Cypress, TX
    Well, I know the thermostat is working because the upper hose gets hot and before the engine get to operating temp the upper hose is under pressure.
    It doesn't make sense to me why it would be running hotter.
    LoneStarStangs Addict Regular Member Dark04GT's Avatar
    Feb 2010
    NC
    If it is running that much hotter I am most suspicious about air bubbles. I don't know how to drained it but hopefully you ran the engine and flushed the entire system. If you have a couple air bubbles trapped in there / didn't fill up your system all the way that could explain your slightly higher temps.
    If it is running that much hotter I would consider flushing again and using a water/coolant mixture with more water. Water is the portion that does the majority of the cooling. I would run something like 60/40 (water/coolant).
    Take a look at this site to double check your draining technique:
    How To Flush Your Mustang Coolant
    DSG 04 Mustang GT
    Performance: C&L CAI, Accufab 70mm TB+Plenum, 24# injectors, Hitech stage 2 cams, MAC LT's, Prochamber, SLP hi-flow cats, Borla Stingers, Steeda UDP, SCT tune, Braille Battery
    Drivetrain: Tri-ax, FRPP Alum d/s, Exedy Mach 400 clutch, Fidanza Alum Flywheel
    Suspension: C-springs, MM CC plates, Tokico blacks, Eibach sways, X2, Steeda bumpsteer, FLSFCs, kyb quads, 17x9's w/ Nitto NT555 275's, Cobra front brakes, Hawk pads & Powerslot rotors
    Mustang dyno: 290rwhp/284rwtq
    A big thanks to Chris@STP for his work on my car
    Sep 2005
    Cypress, TX
    Quote Originally Posted by Dark04GT View Post
    Thats exactly the approach I took. You are absolutely right and I feared the system had trapped air. I burped the system by lifting the front end so it was highest, and running it until hot with the cap off of the overflow. I'm at a loss. I even increased the water in the system. I'll run it again really good today and see if anything changed.
    I suppose it is possible that the flush broke loose crap that is clogging a portion of the radiator so its not cooling properly? That's reaching, but I guess the only way to know would be to get an IR gun and see of there is a cool spot in the radiator?
  6. #6
    LoneStarStangs Addict Regular Member 02silverstang's Avatar
    Apr 2005
    The Woodlands
    here try this hope it helps
  7. #7
    Sep 2005
    Cypress, TX
    Quote Originally Posted by 02silverstang View Post
    Seriously?
  8. #8
    Feb 2010
    NC
    Quote Originally Posted by Rewind351 View Post
    Sounds like you are reaching with the clogged radiator.
    So if the autometer temp gauge is the same and nothing else was messed with during this flush then I wouldn't mess with it too much. As long as the car is not overheating I would drive it around and check the coolant level several times over these next couple of weeks. With the 180 degree thermostat it should not be running that high but being in the low 200's is not that bad either.
    If it keeps staying high you could consider a new radiator / thermostat. Other than that I would wait it out, keep the coolant level topped off and see how it goes.
    DSG 04 Mustang GT
  9. #9
    May 2005
    NE San Antonio
    My thermostat got stuck open and that caused mine to overheat. If the water flows to quickly it doesn't have time to cool in the radiator.
    I can't run an 180 thermo or it will heat up, but with a 195 its fine.
    2012 Mustang GT
