#41 |
Evil Angel
Yeah, I think they were pretty mild... never seen anyone on hear mention anything other than VT...
#42 | ||
I eated it..
VT is suggested simply due to design and duration, along with the LSA of them, but the after market competition has gotten hip and have a whole new batch of 2V N/A cams out there.
#43 |
Evil Angel
No debating here, but what is LSA... don't know that one yet. And are you biased to VT or is there another out there that you would try if you could?
#44 | ||
I eated it..
LSA is Lobe Separation Angle.
Most mod cams are on a 112-116* LSA, but now the newer designs are getting better with 108-110*. I was always partial to VT cams cuz they were designed by a Mustang 4.6 guy and wanted better performing parts. I posted a link somewhere on the HiTech cams, which I like even better now. I may ditch mine and try new ones. I also installed a set of Crower stage 2 cams (which I hated forever) on a almost stock 03 GT and all he had was CAI, TB, plenum, 3 inch over kill (no cats) exhaust and dumped and he made 271/290. Those were on a 109* LSA too. What did yours make again??? 270????
#45 | |
Evil Angel
#46 | ||
I eated it..
As you are aware, to mod a mod motor is not cheap, in either parts or labor. You will benefit from a set of n/a cams mostly.
May get you closer to 280-290, but to reach 300+ you need compression, upgraded fuel system, and possibly some port work will help out.
#47 |
Evil Angel
What do you mean "mostly"? Like mentioned, IF I ever get to that, it will be a while, or when the engine finally needs to be rebuilt... if I still have her by then....
#48 | ||
I eated it..
Cuz you have air in and air out (minus a better intake) but for your mods, the stock is fine, but the cams will compliment your current mods.
#49 |
Evil Angel
So after about a week of it driving fine after the tune, it still popped a P0153 and P1000 last night. Any ideas?
#50 |
Sounds like you may need the tune looked at. Or a bad o2.
![]() www.lethalperformancesatx.com New website Dyno Tuning with: Hp tuners,SCT,Diablo and LT1 edit ![]() Email us at lethalperformance@yahoo.com. We will get back with you Open Tuesday thru Friday 9:00am to 6:30pm Saturday's by appointment only |
#51 | |
I have learned over the years that getting a custom ground camshaft or in this case (camshafts) is the way to go for the best gains and drivability . |
#52 | |
cats and i bet your 02 is done.
Lethal may want to try to sell you you need to have it retuned or your tune looked at but slow 02 response is not a tune issue its a sensor issue. That code means that the 02 on the right bank in the front is reacting slowly to changes made by the ecu to the air fuel mixture during the ecus o2 sensor test cycle. you need to replace the bank 2 front 02 sensor and inspect the wires to it to make sure they are in good condition. if you ever want to look up obd2 codes just go to OBD-II Trouble Codes - OBD-II DTC Trouble Codes Repair Help Site And the p1000 is normal for any ford vehicle with a custom tune if you have the rear 02s turned off wich we did for you because of your busted cats however it doesnt cause a check engine light its the other code that is lighting your cel. That code is simply telling you that the obd-2 self test on the rear 02s did not complete nothing more. < because we turned them off > Your cats are also dying.. i told you that when you were on the dyno. Remember the roten egg smell for the first few few pulls on the dyno ? Remember it was 18-1 at cruise when it came in its around 14.5 now wich is right where you should be.
PSI Performance Solutions 210-655-6546 10811 nacogdoches road San Antonio TX 78217 cmr tuners and full service performance shop. Last edited by psiperformance; 04-26-2008 at 02:05 PM. |
#53 | |
Evil Angel
#54 | ||
I eated it..
As I mentioned on the first page.
#55 | |
#56 |
Evil Angel
So the brand new o2's or at least one of them is shot and needs to be replaced?
#57 |
before replacing a brand new o2, i'd prope it with a labscope and watch the wave forms, that will tell you for sure, but it's possible you just got a bad one, it happens from time to time
#58 | |
You need some one who can datalog the car. With SCT or anything else.
My personal profile and my .02 ![]()
#59 | ||||
I eated it..
Does your handheld you have have that ability? Otherwise, you may need your tuner to read it for you.
#60 | |
Evil Angel
