#61 | |
re re
Basic description of stock cats..
Catalytic Converter Design Performance cats have stainless steel cores inside with less restrictions and materials. Not to be a shit, but as many questions that you ask, you should also take the time to either run searches or use google for information. There is a plethora of knowledge out there and can answer 90% of your questions faster.
#62 | |
Evil Angel
#63 | |
re re
Actually, I have answered many of your questions, I have never said anything on what you can and cannot ask, yes this is a forum, but from my perspective, you do ask (as well as Cody, although he asks 10x more then you do) lots of questions. Sometimes self education is best, sometimes it is not.
Stock OEM cats (as the link I posted) tells you what materials are used and I suggested a google search for more info. Your cats have a stainless steel core which does not have the same materials, basically, like a giant MIL eliminator in a sense. Without adding more confusion on your part and typing things that I think you should have a basic knowledge of or want to attain, I'll just in the future, not post in your threads. Other member or google can assist you better then I, I guess.
#64 | |
Evil Angel
#65 |
Evil Angel
Ok so just got back from hanging out with some friends... and after opening her up a lil'... the engine light went off. I had a feeling this might happen, similar to how it ran on the dyno Dean when you had to keep revving it waiting for the o2 to pick up the reading. Just that slow response needing a good wakeup call... I don't know... but it's off for now... I'll still look into replacement cats possibly...
#66 | |
![]() Or if you have a live wire you can display it. ![]()
My personal profile and my .02 ![]()
#67 | |
#68 |
that's pretty cool, i wasn't aware that it could work like that.. i just use my snap-on vantage because it's real time... i'm guessing through the hand helds, it's data logging, not actual real time... but in the end, any of these methods would work to test an o2 sensor...
t-5 swap, billit quadrant, upr firewall adjuster, steeda tri-ax, custom jb tool and fab one off subframe connectors. coming soon: 8.8 w/ 3.55:1's, '00 gt brakes, followed by my 306 swap |
#69 | |
![]() Last edited by H0SS302; 04-27-2008 at 10:01 AM. |
#70 | |
#71 |
how can you get real time through the dlc? i guess i'm being mislead somewhere, i was under the assumption that through the dlc you will always have a 3-5 second delay.
#72 |
i dunno lol when i would rev the throttle the gauge moved with it. when i play it back it is choppy n stuff but when im actualy in the car, i could prop the laptop on the dash and look at that instead of my cluster.
#73 |
No delay its realtime data. Just like the new X3's have.
#74 |
that's awesome, i've been learning a lot of diagnostic stuff, and i guess it's the scanner that has the delay.. that's pretty cool... it would be hard to drive a car around with a labscope hooked up, a livewire or the other thing would be much easier to get real time... do you know of anything i can use on a fox for similar results?
#75 | |
#76 |
can i adjust fuel trim etc etc with it? i'm not finding a straight answer on their site
#77 |
wat are you looking for here? do u want a data logger or a tuner/data logger?
#78 |
tuner/datalogger that i can tweak from a laptop in my fox
#79 |
i would suggest sniper but i think they only go back to '96
does your car have obd2? |
#80 |
Evil Angel
All y'all are doing is talking about datalogging now!!! And no... to the best of my knowledge OBDII is 96+
