Evil Angel
Ok, so as I guess is the typical case... I'm now finally running lean according to my ecu after about 3 weeks with almost all the bolt-ons on. The last addition was Kook's L/T's which threw a code at first, then it corrected it self, and then threw the codes again monday. MIL has been on since due to P0133, P0153, and P1151. It still feels the same driving, so I'm not too worried about it, but I don't know if I should be. What I want to know is what are your suggestions to remedy this... Would a larger injector cure this? A custom tune easiest route?? Am I causing any harm by driving under (normal conditions of course) for any certain period of time. All mods can be seen in my sig and thanks for any info.
#2 | |
LoneStarStangs Addict
P0133, P0153 -Oxygen Sensor Circuit Slow Response caused by * The oxygen sensor is faulty * The wiring to the sensor is broken / frayed * There is an exhaust leak P1151- Lack of HO2S-21 Switch, Sensor Indicates Lean cause by Electrical: * Short to VPWR in the harness or HO2S * Water in the harness connector * Open/shorted HO2S circuit * Corrosion or poor mating terminals and wiring * Damaged HO2S * Damaged PCM Fuel System: * Excessive fuel pressure Leaking/contaminated fuel injectors Leaking fuel pressure regulator Low fuel pressure or running out of fuel Vapor recovery system Induction System: * Air leaks after the MAF * Vacuum Leaks PCV system: * Improperly seated engine oil dipstick EGR System: * Leaking gasket * Stuck EGR valve * Leaking diaphragm or EVR Base Engine: * Oil overfill * Cam Timing * Cylinder compression * Exhaust leaks before or near the HO2S(s) |
#3 | |
re re
Larger injectors will do you no good as the PCM will still think they are stock unless told so by custom tuning. Tuning around it will be your best bet and get maximum power along with fuel economy, best not to stay in it (unless you know what ping sounds like) then get out of it. Running lean at WOT = bad. Better to run fat then lean at WOT.
The pcm can only compensate for so much.
#4 | ||
Evil Angel
#5 | |
re re
Ford's 02 sensors have a tendency to learn lean and rich conditions which lead to slow/lazy readings and ultimately failed sensors. The above poster obviously did a copy and paste from a google search I imagine and is correct in a sense for factory tables and stock applications, however, when you change things that modify air flow in and out (along with other supporting mods) the PCM can only compensate for so much, that is when the custom tunning comes into play.
If it is worth anything to you, my MIL will turn on on occasion (giving me a lean code for bank 2). I know there are no vacuum leaks, much less over filled oil, exhaust leaks or failed/lazy 02 sensors (in fact, mine are quite active). Running with it untuned may or may not result in a failed 02 sooner or later, but then again, many repair shops will recommend replacing them every 30-60k miles, depending on applications.
Evil Angel
#7 | |
re re
If the 02 reads lean more times then not, it builds a memory. Kind of like a bed, the more you lay in it, the more prone it is to developing a dip where you sleep. Primitive, I know, but it is a good example.
And I know for a fact, there are no exhaust leaks and the 02 sensors I installed are relatively new, low mileage 02 sensors.
Evil Angel
So is a tune going to turn off the sensors or tell them to read a different range? Or would the air/fuel/timing just be adjusted with a tune to compensate for the lean condition??
#9 | |
re re
The latter since you have cats.
Evil Angel
Damnsit.... now where the heck am I gonna get it tuned is the question...
Any shops have openings soon???
Does the CAI you have have a sharp bend right before the MAF. I've heard quite a few times of this causing a lean condition.
'02 Stang GT Just cause you don't understand what's going on ...don't mean it don't make no sense And just cause you don't like it,...don't mean it aint no good And let me tell you something Before you go taking a walk in my world,...you better take a look at the real world Cause this aint no Mr. Rogers Neighborhood Can you say "feel like shit?"Yea maybe sometimes I do feel like shit I aint happy about it, but I'd rather feel like shit than be full of shit! And if I offended you, Oh I'm sorry, But, maybe you needed to be offended But here's my apology and one more thing........Fuck you! Cause you can't bring me down |
Evil Angel
I wouldn't call it sharp, but it's about a 90* technically. It's a nice large diameter coming from the fender. It's a Roush in case you didn't see that in the sig. Almost all of the fender kits are like that though, so I would have to change intakes to get around that.
You could try rotating the MAF and se if it would help.
Evil Angel
What are you talking about???
this is what LTs have done on every 4.6 i have ever seen who actually admitted the issues they had instead of just saying "they are great"
you need a tune. You can get a sc tuner and order it with your mods from modular depot. or you can go to any of the 5 people that dyno tune mustangs in the area and they will get you within 5 hp of eachother. Murrillo psi lethal henderson Maximum velocity...
#16 | |
Evil Angel
#18 | |
re re
You can't just do a walk in and expect them to drop what they are doing for you, you have to understand the reason shops take a while is due to the mass work in there. be patient, set an appoinment, get in in and done, if you rush them, you will get a shitty tune.
#19 | |
Evil Angel
#20 | |
