Old 04-11-2008, 09:24 PM   #1
izzy jr's Avatar
Question rust treatment/removal
What can I use to help prevent the small rust spots on my car from getting any worse until I can get them fixed??
66GT "Wish List"
izzy jr is offline   Reply With Quote
Old 04-11-2008, 09:28 PM   #2
MR.SUPER TECH
Ryan_65Stallion's Avatar
they have rust removers and such in spray form at the parts house, unless you cut it out, thats the only way to stop it, bondoing over it will not stop it but just cover it.
1965 Mustang, 2V 289 V8, C4 automatic 3 spd
Mods: Edelbrock Performer 289 intake manifold, Holley 4brl 600cfm carb, Grab-A-Trak 560lb 1'' drop springs, MBMotoring 15'' wheels, 14'' K&N Extreme Air Filter Assembley, all aluminum radiator
My Streetfire.Net MyMustangSite My Myspace!
Old 04-11-2008, 11:01 PM   #3
It's LOUD but YOU looked!
stangfreak's Avatar
sand it down to metal, seal it and primer it
Deep thought...
Old 04-11-2008, 11:18 PM   #4
Street Stylin' Stangs
saleen-00's Avatar
Send a message via MSN to saleen-00
ive seen people put orange glow and scrub it and the rust comes off i was surprised that it really works
2000 LAZER RED SALEEN #0263
373s, 70MM throotle body ,port and polished intake, bassani x pipe,
3''magnaflow tips, mac cold air ,100 shot of nitrous
7'' keenwood flip out screen two 10'' JL audio subs with jensen amp
saleen-00 is offline   Reply With Quote
Old 04-11-2008, 11:34 PM   #5
stangfreak's Avatar
wow, thats cool, I will have to try that.
Deep thought...
Old 04-12-2008, 12:29 AM   #6
time for change
keg65's Avatar
there is a product, most autoparts and even walmart have it. Rust Converter, kinda like navel jelly, but it is supposed to "convert the rust into a black primer" You are supposed to clean off the metal of dirt and loose rust, then paint this stuff on. I have used it, but never really put it to any test.
Flowmaster axleback, Sniper Special Forces tuned and coming soon JLT CAI
Old 04-12-2008, 12:39 AM   #7
stangfreak's Avatar
you have to be careful with those
Deep thought...
Old 04-12-2008, 12:48 AM   #8
time for change
keg65's Avatar
other than the staining, what do you mean?
Old 04-12-2008, 09:49 AM   #9
izzy jr's Avatar
I do plan on having the rust spots cut out and patched prior to painting, for now I'm looking for the best way to prevent it from spreading or getting worse until I get the car painted. For the most part the car is really clean. It has one small spot on the drivers front fender in front of the door,lh rear lower wheel well panel has some rust, small spot on rh corner of the panel under rear window, nothing terribly bad yet. Since I don't have the tools to paint the car I'll eventually be taking it to someone to paint and don't want to do anything to cause more work than needed for the paint.
66GT "Wish List"
Old 05-02-2008, 10:48 PM   #10
izzy jr's Avatar
Started tearing the rearend apart this afternoon. only thing left holding the rear-end in the car is the e-brake cables that I still have to disconnect, then I'll drop the leaf springs down and start sanding away at the rearend. Discovered that the left rear shock doesn't have any pressure on it at all, you can sqeez it together and let go and it just stays, the right side will extend back out.Quess it's a good thing i'm swapping all them out anyway.
66GT "Wish List"
