What!! The 5.0 broke??
seat belt sleeve tool removal
I just got seat belt sleeves for my 89 and not sure of the size tool I need to take them off,any one know? Thanks folks!
89 GT "THE TOY" |
#2 | |
Dumb and dumber
If memory serves me, it is a 55 torx bit
Coming to a 17" rim near you
your memory is great.. why cant they just use one damn bolt style for the whole car.. torx hex, metric, standard... that crap gets anoying..
#5 | |
Dumb and dumber
They still use it on the newer ones too, just the lower bolts though.
i got mine at advance auto.. didnt last long tho(when i was putting the bolts back in the edges of the torx curled in..POS bit.. i would check sears for a craftsman.
#8 | |
2002 Mustang GT-K&N FIPK, Accufab Plenum/ 75mm T-body, Diablosport Predator, 4.10s, Pro 5.0 shifter, Bassani O/r x-pipe, Magnaflow Magnapacks, Steeda pulleys, Mickey Thompson ET streets, Moser axles, Eibach Sportlines, Hotchkis U/Lca's, 180* t-stat_ best e.t 13.02@103!!!! Soon to come: Weight reduction, weld pro-stars and fox springs.
I bought a decent set at Orielys a few yrs back still have um and still work great. If you are not using them daily they will ast a Pro Mech needs the high dollar stuff for daily use.
Although Craftsman is good a replacing all my broke stuff. I need to take a 1/4 in ratchet back lol
