Closed Thread
Results 1 to 12 of 12
Thread: semi-built fox/sn-95 rear
    FAIL Regular Member
    Aug 2005
    college station, tx
    31-spline trac-lok, low miles.
    31-spline superiors(i think, can't recall for sure) with 3" studs installed.
    FMS 3:73 gears
    has a T/A girdle installed.
    currently has fox-length axles in it with neighbors' brackets installed for 13" limo rotors.
    can install the sn-95 axles with stock studs.
    500 with the fox/neighbors brake setup
    400 with just the fox assembly(no brake setup)
    450 setup for sn95/disc
    Come chase this ass Regular Member machgsxr's Avatar
    Mar 2007
    San Antonio
    Quote Originally Posted by DINO View Post
    FMS 3:73 gears
    What is the neighbors brackets and 13" limo rotors? How many miles on the gears? Is it setup for abs or no? Are the tubes welded?
    Im interested in it though because this is the size housing i need. Not really concerned if the tubes are welded or not. Just thought I would ask.
    03 DSG MACH - TT - Not fast enough
    03 OW MACH - Slower than above
    11 RR GT/CS - Slower than both of the above
    Thanks to Longoria Race Cars
    FAIL Regular Member
    Aug 2005
    college station, tx
    chris neighbors build brackets to use the later GT/cobra calipers on GT, cobra or 13" town car limo size rotors. only works with fox-length axles. less than 5k on gears, no whine. the sn95 superior axles i have do not have rings. tubes are not welded( i had no plan of super launches, just normal drag radial/street driving).
    FAIL Regular Member
    Aug 2005
    college station, tx
    got an offer of 300 for the rear w/ no brakes and about an hour drive. anybody wanna beat it?!
    Box Foxes Rule!!! Regular Member racer99's Avatar
    Feb 2005
    Cowboy Capital of the World
    Chris is a good guy,I still have 2 boxes of his
    parts in my shop.
    of stupidity!
    Just damn junk with a blow through
  6. #6
    Mar 2007
    San Antonio
    Would you mind holding it for me while im passing through H-town next month?
  7. #7
    FAIL Regular Member
    Aug 2005
    college station, tx
    can hold with half deposit. what setup you need it with?
    that would be fine. i can keep the car a roller that way. lol.
  8. #8
    FAIL Regular Member
    Aug 2005
    college station, tx
    feel free to text me with any questions, won't be online for most of the weekend. 281 813 0613
  9. #9
    Mar 2007
    San Antonio
    I don't need any of the brake brackets. I don't think. Can you take a pic of the end so I can make sure what I have in my mind will work. Im hoping it will.
  10. #10
    FAIL Regular Member
    Aug 2005
    college station, tx
    what are you trying to make work?
  11. #11
    Mar 2007
    San Antonio
    lol. Just a little bit, but nevermind. I found the answer I was looking for. Sending you a pm.
  12. #12
    FAIL Regular Member
    Aug 2005
    college station, tx
    all SOLD.
Closed Thread
