Old 01-28-2005, 11:27 AM   #1
SES Light
Has anyone experienced this? My SES light came on after I had a 75mm Throttle Body and new Plenum installed. I have an '04 GT.
shadow stang is offline   Reply With Quote
Old 01-28-2005, 11:35 AM   #2
in a happy place
TrueBlueVenom's Avatar
normally the light should go away after driving it for 20-40 mins. try resetting your ECU overnight (of course you'll lose your radio presets):
-unhook battery
-turn on headlights (to drain any residual juice in the system)
-let sit overnight
-next day, rehook battery. turn off headlights.
-start car (will run and drive ragged at first until the ECU relearns)
-after warming up, take a casual drive (to allow ECU to relearn)
I have a CAI, 70mm TB, and plenum on my 02 GT - no light.
Old 01-28-2005, 11:40 AM   #3
Man, I've had the damn light on for 2 weeks! I'm taking it back tomorrow to the shop that did the work so they can put a scanner on it to clear it up. Just wanted to see if it was normal or what. Thanks for the info though.
Old 01-28-2005, 12:07 PM   #4
"The Hitman"
Hammered's Avatar
unpluggin the battery will clear it...but does it come back?
Old 01-28-2005, 12:36 PM   #5
See what's weird is that is did come off, I went and raced it. Then the next morning it was back on and hasn't come off since.
Old 01-31-2005, 09:10 PM   #6
Jus Workin Away !!!
txlen's Avatar
what is the vehicle info??..year??...tranny??..some info mite help..
Old 01-31-2005, 09:12 PM   #7
Go to Autozone and the can run the codes for free.
larry03gt is offline   Reply With Quote
Old 01-31-2005, 09:33 PM   #8
Sorry.
2004 Mustang GT, 5-speed
The code that keeps popping up is P2272 and it says on the shop's book that did the work to SEE SERVICE MANUAL.
Old 01-31-2005, 09:36 PM   #9
I just tried to look up that code and it's not listed. Are you sure they gave you a correct code?
Old 01-31-2005, 09:44 PM   #10
I'm with you on that one. I can't find it anywhere either. If I go to Autozone, do I just tell them to run a scan on it? And it's free? Thanks for helping me out. I'lll also call the shop tomorrow again to make sure it's the right code. They wrote it down as P2272.
