Shifter install!!!
So I get a tri ax the other day and my mechanic buddy who's going install it for me at his work is suddenly somebody I can't talk to right now!! To long of a story to get into So now I'm looking for a place to install my shifter and where I bought it was a little high imo. Any Ideas of a place in S. Houston Clear Lake area where I can have it done? No do it yourself replies please. I have no tools and mechanically challenged. thanks, Jimmy
what year is your car? or what transmission are you installing the shifter on?
'84 fox convertible. E7 roller block .030 over with Hyper. pistons and stock stroke for now. E7 heads, Weiand Stealth intake, holley 4777, comp cams magnum 290 cam and springs, and complete MSD ignition. MAC equal length shorty headers to BBK O/R X-pipe to dual chamber flows. Electric fan conversion. '92 silver ponys. Just added, UPR non adjustable upper and lower control arms, Eiback Pro drop springs, MGW short throw shifter, billet overflow tank, and a few other billet accessories. |
How soon are you looking to put it on your car?
Next Friday and Saturday, I am going to be working on my car, and I can help you put your shifter in. It is the same style shifter that i have on my t5 except mine is a MGW. Let me know and i can help you next weekend. I will be in Santa Fe just south of Clear Lake, so it would not be that far for you to come out.
#5 | |
Coming to a 17" rim near you
this is an incredibly easy install...Can you turn a socket wrench?
all you need is a 10mm socket, 13mm socket and socket wrench(a small extension and a swivel socket) you can go to an autoparts store n get all of this for 20 bucks or so.. and you also need a tube of rtv gasket maker. go to your shifter and grab the trim molding around the boot at a 10-4 o'clock position. pull straight up to the roof firmly(but dont yank) if you have a 12v power plug your gonNA need to undo the wire after you get the trim off. after that, you take off the 4 10mm bolts(iirc on the size) and take that cover off. you should then see the other 4 13mm bolts of the actual shifter. take those out then pull off the shifter(9-10 your gonna need to tap the shifter base loose with a hammer or something) get a razor blade and scrape the old gasket off and aply the new gasket silicon...then bolt up the shifter and put the plate back on.. its VERY easy. maybe an hours work if you stop to drink a soda if you have a t45 tranny your gonna want to set your shiftstops( there is a thread in the general section on this...also very simple) just follow the direction, steeda gives great pictures and describes in detail what to do.. you will have no issues i promise |
drewskie68
^^^^+1 veryyy easy. first thing i ever did by myself on my car. the only problem i had was my old shifter was a pain to get out so i had to jack the car up and get under it to pry it off
all i did was stick a hammer sideways between tranny and the trim and use the claw to pry it off.
drewskie68
ii did not even think of that... i had to go to my gfs dads house and get a jack and junk. they jus repaved the alley behind my house where i live and the jackstands started sinking while i was under the car lol a hammer woulda saved me a lot of trouble
#10 | |
work smarter, not harder ![]() |
just did my tri-ax tonight......easy swap, had trouble getten to the top two bolts that hold the cover on.......set the stops with enough room slid a folded dollar bill threw it......shifter is crazy how short you have to move it to switch the gears.....like im not even moving it to get it to hit um....very pleased with it.
1989 LX Coupe 5.0 HP/457 TQ/448 Um......STOCK? LOL |
#13 | |
its harder on a fox.. top 2 bolts are a pita... not on the 04 though. just get someone local who has basic hand tools to help you.. instructions are verry good, and if they charge you more than a few beers, they're ripping you off...
Jimmy,
How are you liking your new shifter? Pretty easy to install HUH? Have a good one.
#16 |
It's great!!! The shifts are much shorter and the power band stays more consistent. Instead of dropping during shifts between gears. It is louder than stock but I just turned the radio up a little and couldn't hear the tranny noise. Over all I love it!!!! Thanks Brett I'll be in touch for the shorty antenna install and the new shifter knob install also as soon as they come in!!!! Just kidding once again thanks for the help!!!! Jimmy
#17 | |
drewskie68
is that normal?? i can hear noise coming from my shifter too |
#18 |
Everything I've read about tranny noise is because the new shifter isn't as insulated as the stock shifter. If it bothers you check into getting a new boot from MGW maybe that wil insulate it better..
#20 |
yea mine is the same way.....lot noisier...plus seems its so tight when i downshift hard it like misses going down into 4th.........i guess just not use to having to shift it like the stock one, shoft one has my shifts off so use to the stock one i had, this one is very tight in the shifts.......but yea mine is lil noisier too.
