Old 04-19-2005, 03:03 PM   #1
#1 baby thats Awesome with a captial A
BlackRob's Avatar
Send a message via AIM to BlackRob Send a message via Yahoo to BlackRob
Shifter switch questions?
Anybody know how hard it is to switch out for a short throw shifter? Or is it just a simple pop out and replace job?
Also how long it might take to do?
Black 98 GT vert, codename: "Vader"
247 hp and 290 tq NEEDS A TUNE!!
Mods: New vert top, Deep Dish Black Bullitts, Steeda Tri-Ax shifter, billet grille w/pony cutout, PI heads, PI intake, valve covers, CAI, Bassani X-pipe, Flowmaster catback, LSS decals, Bumper inserts, black clear headlights, and lots of ZAINO!
Remember, I didn't vote for his bitch-ass!
BlackRob is offline   Reply With Quote
Old 04-19-2005, 03:24 PM   #2
VIC
The "Senior" Member
VIC's Avatar
Send a message via AIM to VIC
Really is is quite simple.
Remove the plastic bezel around the shift lever. Put your fingers at 4 and 8 o'clock and just pull up gently.
Remove the rubber sound deading material. This may or may not be reused depending on the brand of short throw shifter you have.
Remove 4 bolts and lift old shifter out. It maybe stuck (like glued) on there and may need a few light taps with a hammer on the side to break loose.
Remove old shifter and clean off the old gasket material from the top of the rtansmission. Be careful not to let any pieces fall into the transmission. There is a teflon cup in there that goes over the ball at the end of the shifter. You reuse that.
Apply a (blue) gasket material to the new shifter and bolt down.
Replace bezel. 30 Minutes max.
The new shifter should come with longer bolts. The Tri Ax does.
Old 04-19-2005, 03:38 PM   #3
Yup pretty simple job 30-45 min as Vic states.
Also dont forget to set the stop bilts on the new shifter.
Old 04-19-2005, 03:40 PM   #4
VIC
The "Senior" Member
VIC's Avatar
Thanks.....forgot about that small detail...
Old 04-19-2005, 05:11 PM   #5
Man law?
Bring it over and ill do it for a 40 oz. :scottyboy Had them on both my stangs.
Old 04-20-2005, 01:23 AM   #6
BlackRob's Avatar
How about I bring ya a dozen and ya fix that, my stereo, and apply my LSS decal on my windshield??
