Old 05-18-2008, 10:54 AM   #21
X2CRAYZIX's Avatar
Send a message via Yahoo to X2CRAYZIX
ok , thanks for the advice
X2CRAYZIX is offline   Reply With Quote
Old 05-19-2008, 09:22 PM   #22
highspeed's Avatar
I'd look at the TFS stage two or three cams. You may need to have the pistons fly cut with the stage two... definitely with the stage three. Stick with 1.6 roller rockers and get an Intake to compliment it all. Edelbrock and TrickFlow have some nice intakes for the 5.0 motors.
You will also want to consider upgrading the MAF (75-80mm) and injectors (24 lb) along with a 255 LPH fuel pump.
It will all work together... but you need to be sure to balance it all or you will not get the desired gain or output.
I think the long tubes can wait as you will lose some bottom end torque with them. I would get them later though when you finish your top end.
Modz Update!!!
WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
  • MAF support brace - '94 GT
  • Maximum Motorsports Panhard Bar
  • Canton radiator overflow reservoir
  • Fidanza or Spec Billet Steel Flywheel - (50oz 302cid 10.5" 157 tooth)
  • T56 Tranny with 5.0L Bellhousing & support brace
  • Maximum Motorsports Tubular K Member
  • Maximum Motorsports Tubular A Arms (std offset)
  • Coil over struts
Old 05-20-2008, 06:26 AM   #23
CraZy6's Avatar
HE just needs a cam under .500 lift. and he will be fine and safe for the piston to valve clearance. Piston fly cutting requires more money and finding someone or some place to do it correctly. And 1 5/8" Longtubes there is no loss of torque. My car ran good when I had an E-cam, BBK Long tubes 1 5/8", X-pipe with flows w turndowns, 3:55 gears, 65 mm TB, 75 mm MAF, 19lb injectors and 9" conical K/N filter. And you could tell a big difference. All this can be done at a reasonable price. IT just depends on his budget.
CraZy6 is offline   Reply With Quote
Old 05-20-2008, 11:21 AM   #24
Brewmeister
coupe5oh's Avatar
I agree, stick with 1.6 rockers.
retired 1990 Tx dps :T-5, stock bottom 302, shorty headers,o-r x-pipe, ported explorer true gt 40 heads, matching intake. E-cam 1.7's, pro-m 77, 24lb injectors, 3.90 gears.
good for mid 12's on stickies.
Old 05-20-2008, 11:23 AM   #25
Brewmeister
coupe5oh's Avatar
With stock pistons I run the e-cam, w/ 1.7 rockers, that put's me at .529/.529, no clearance issues, im sure it's a little tighter than some people would recommend, but runs fine. A long 'duration' is what can create a clearance problem as well, should be checked/degreed with every cam, because you never know.
Old 05-21-2008, 05:08 PM   #26
comp xe276 blower cam
AFr 165s with upgraded springs
Holley systemax with an accufab 75mm TB
There I just built your 330whp combination, send 5 dollars to my paypal account
Old 05-21-2008, 07:05 PM   #27
highspeed's Avatar
Modz Update!!!
  • Coil over struts
Old 05-21-2008, 07:13 PM   #28
highspeed's Avatar
I am also currently running an E cam with 1.7 roller rockers... It runs nicely... but I would prefer just a bit more punch out of the car.
I'd check into a tfs stage 2 cam or something comparable with 1.6's and verify clearances with the manufacturer to make sure it wouldn't require fly cutting the pistons... you would probably want to stay away from the cams that require flycutting the pistons unless you end up doing a complete rebuild on your motor.
Modz Update!!!
  • Coil over struts
Old 05-22-2008, 12:13 AM   #29
Lifted78Chevy's Avatar
LOL yea your pretty close with those parts to 330....but is that at the fly or to the ground........me, i'd go 165afr, b-cam, 1/7's, cam will have 510 lift pistons be fine, trick flow intake, 70mm throttle body, 75 mm mass air, 24 injectors, bbk long tubes, x pipe, flows dumped, msd ignition, pro-m power pipe, k&n filter and i promise you will make 335 hp to the ground.....then later on put a blower on it and your'll have 400 plus hp...am i missing anything???? o yea put a better cam in if u want make power over 5500 rpms....lol.
1989 LX Coupe 5.0
HP/335
TQ/362
list goes on forever....she slooowww!!
Old 05-22-2008, 10:44 AM   #30
I swear I am going to go off the deep end if you guys dont stop recommending piece of sh*t outdated cams with no matching correlation to his head and intake combo.
STAY AWAY FROM HUNDRED DOLLAR CAMS. E B F X TFS1 TFS2 old school crowers
you will be far far far far faster buy spending 300 on a cam that is relevant and skimping out on say a 200 dollar TB or something else
Unless you are going with a proven combo that one of these cams is perfect for (rare), dont use it.
you can make 300+ RWHP with AFRs and a retarded stock cam BTW. It will probably out run your average 310hp AFR e303 or tfs stage 1 combo, especially if you fear the gear and have say a 3.73.
Save your dough and put it where it counts.
