#22 |
I'd look at the TFS stage two or three cams. You may need to have the pistons fly cut with the stage two... definitely with the stage three. Stick with 1.6 roller rockers and get an Intake to compliment it all. Edelbrock and TrickFlow have some nice intakes for the 5.0 motors.
You will also want to consider upgrading the MAF (75-80mm) and injectors (24 lb) along with a 255 LPH fuel pump. It will all work together... but you need to be sure to balance it all or you will not get the desired gain or output. I think the long tubes can wait as you will lose some bottom end torque with them. I would get them later though when you finish your top end.
Modz Update!!! WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
#23 | |
#24 |
Brewmeister
I agree, stick with 1.6 rockers.
retired 1990 Tx dps :T-5, stock bottom 302, shorty headers,o-r x-pipe, ported explorer true gt 40 heads, matching intake. E-cam 1.7's, pro-m 77, 24lb injectors, 3.90 gears. good for mid 12's on stickies. Last edited by coupe5oh; 05-20-2008 at 11:24 AM. |
#25 | |
Brewmeister
retired 1990 Tx dps :T-5, stock bottom 302, shorty headers,o-r x-pipe, ported explorer true gt 40 heads, matching intake. E-cam 1.7's, pro-m 77, 24lb injectors, 3.90 gears. good for mid 12's on stickies. |
#26 |
comp xe276 blower cam
AFr 165s with upgraded springs Holley systemax with an accufab 75mm TB There I just built your 330whp combination, send 5 dollars to my paypal account
#27 | |
#28 | |
I'd check into a tfs stage 2 cam or something comparable with 1.6's and verify clearances with the manufacturer to make sure it wouldn't require fly cutting the pistons... you would probably want to stay away from the cams that require flycutting the pistons unless you end up doing a complete rebuild on your motor.
#29 |
LOL yea your pretty close with those parts to 330....but is that at the fly or to the ground........me, i'd go 165afr, b-cam, 1/7's, cam will have 510 lift pistons be fine, trick flow intake, 70mm throttle body, 75 mm mass air, 24 injectors, bbk long tubes, x pipe, flows dumped, msd ignition, pro-m power pipe, k&n filter and i promise you will make 335 hp to the ground.....then later on put a blower on it and your'll have 400 plus hp...am i missing anything???? o yea put a better cam in if u want make power over 5500 rpms....lol.
1989 LX Coupe 5.0 HP/457 at the fly-514 est. loss 12% get it to the ground TQ/448 at the fly- 501 est. loss 12% to get it to the ground Tuned at PSI...all the power made below 5500. Um......STOCK? LOL...could be. |
#30 |
I swear I am going to go off the deep end if you guys dont stop recommending piece of sh*t outdated cams with no matching correlation to his head and intake combo.
![]() STAY AWAY FROM HUNDRED DOLLAR CAMS. E B F X TFS1 TFS2 old school crowers you will be far far far far faster buy spending 300 on a cam that is relevant and skimping out on say a 200 dollar TB or something else Unless you are going with a proven combo that one of these cams is perfect for (rare), dont use it. you can make 300+ RWHP with AFRs and a retarded stock cam BTW. It will probably out run your average 310hp AFR e303 or tfs stage 1 combo, especially if you fear the gear and have say a 3.73. Save your dough and put it where it counts.
2007 Reflex Silver Wolfsburg Jetta - new hotness 1995 Canary Yellow GTS - Sold 12.81@106.2 w/1.80 60' Boltons/E303 + 3100 lbs + M&H 246 HP/ 290 TQ 12.57 @ 109.21 w/1.76 60' Boltons/GT40Ps/XE270 + 3240 lbs + 555Rs 295 HP / 321 TQ Last edited by 95 GTS; 05-22-2008 at 10:47 AM. |
