1990 GT
BBK Cold Air intake MSDdistributor Ford racing wires underdrive pulleys Power+Plus Typhoon manifold 70mm Throttle body o/r h pipes with flows dumped Could anyone tell me what kinda of cam i should use as an upgrade. Also could anyone recommend what fuel pump i should use (other than oem part) 155 LPH , 190 LPH? and what brand is best? Last edited by X2CRAYZIX; 05-16-2008 at 03:09 PM. Reason: added more |
Brewmeister
you need some good flowing heads or else your wasting your time, the stock cam and 1.7 rockers is a good combo until you get some massive heads.
retired 1990 Tx dps :T-5, stock bottom 302, shorty headers,o-r x-pipe, ported explorer true gt 40 heads, matching intake. E-cam 1.7's, pro-m 77, 24lb injectors, 3.90 gears. good for mid 12's on stickies. |
Thank you guys for your info ....ok what type of heads should i get?I really dont know where to go with this car but i do know i want to be able to still drive on the street and once in awhile at the track for fun..
easy.......afr's or trick flow heads......from 165 to 185, your'll be pick up 50-75 hp easy with these heads and a cam and intake.......i pickup 120hp with the small afr 165 heads, car be very fun to drive......if your not sure on all the nuts and bolts in doing a head swap there some great shops here in sa that help ya out and do some dyno tuning get the most out of your ride.
1989 LX Coupe 5.0 HP/335 TQ/362 list goes on forever....she slooowww!! |
Find some used but clean AFR 165's and spend a few bucks on a custom hydraulic roller cam from FTI (Ed Curtis) .
I'd also have someone do some minor clean up work to the intake and install a 1/2 phenolic spacer . As for fuel pumps , go with a 255 Walbro . It will be plenty big enough down the road and cost about the same as the smaller ones .
Box Foxes Rule!!!
Keep the intake valve @ 1.94 on any
except maybe the TWs and be sure to check piston to valve clearance. You dont list any exhaust mods. Have you got aftermarket headers with that exhaust?
Never underestimate the unpredictability of stupidity! 78 Zephyr, 306 turbo 82 Granada Wagon,306 150 shot 88 Mustang 2.3 turbo 100 shot Last edited by racer99; 05-17-2008 at 01:22 PM. |
#17 |
If that directed to me... thats fine, i was joking around seeing what kicks and giggles i could get, Good luck with your car...
#19 |
I have a custom FTI cam 499/499 lift, just a little bigger than an E-cam. $100 shipped. And its a perfect cam if you wanna use a power adder as well. Its just sitting in my garage after I pulled it out of the (1200 miles)306 I bought and I put a X-cam in its place.
#20 |
If you end up with some AFR's or anything near that in size , do yourself a favor and buy long tubes and matching X pipe .
