Old 07-17-2007, 12:36 PM   #1
PearlWhiteGT's Avatar
Should I use a T-Rex or not?
I bought a used S-Trim for my pretty much stock 306 with 15K miles but it didn't come with a T-Rex or FMU. I'm going to run a PMAS 80mm & some 42lb injectors. I have a 255 intank fuel pump so my question is do I need to run a T-Rex or will I be o.k. with out one? What do you think would be the best way to go? Only plan on running about 10 psi & plan on having it tuned.
PearlWhiteGT is offline   Reply With Quote
Old 07-17-2007, 12:37 PM   #2
4.6coupe's Avatar
Send a message via AIM to 4.6coupe
255 is all u need
NOShit www.sponsorhouse.com/Members/tonir
4.6coupe is offline   Reply With Quote
Old 07-17-2007, 01:01 PM   #3
yea.. it's only purpose is to boost the fuel pump... and with a 255, you should be good to go...
Old 07-17-2007, 01:05 PM   #4
Nazi Mod
Originally Posted by 4.6coupe View Post
255 is all u need
Old 07-17-2007, 03:16 PM   #5
I would install a T-rex or some type of inline pump to help your 255 lph. I would not use an FMU, with your 42 lb inj and a 255 pump with an inline you should be good for around 600 hp at the flywheel.
TurboGA is offline   Reply With Quote
