Old 04-17-2008, 08:09 PM   #1
sorry if this question gets asked alot
sorry everyone if this subjects been beaten to death but i can seem to find some answers to my questions.
first i have a 95 gt auto(aode) off road x pipe 2.5 inch cat back silencer removed 15d ignition 17 inch konigs fuzion tires forgot type.
i have a 3.27 rear gear installed in it now what kinda increase in my 1/4 will i seeif i switch to 4.10?
are headers worth buying to "complete" my exhaust or should i go with a c&l intake kit?
also should i get standard shift kit or get the full manual type?
just to let you know i have to put the car in first before i put it in drive anyhow so ive been going manual anyway just havent heard of anyone doing it.
sorry again just need some help. eventully id like to see 11's but i think stock mustangs run a 16sec 1/4
5.0 auto x pipe full exhaust removed silencer konigs cai bbk 75mm tb smog elim pulley more to come
jeffmarble is offline   Reply With Quote
Old 04-17-2008, 09:42 PM   #2
Hitman84's Avatar
i am running a 95 block 302 in my fox and i noticed a huge jump in low end torque when i put on my mac equal length shortie headers. i have not taken my car to the track yet, but i am running 3.55's in my rear end and it still get decent fuel economy and will get up and go with the rest of them. if you are looking for any kind of DD use with your car i would recomend 3.55's or 3.73's. 4.10's are going to consume far more gas than these gears and you may only gain tenths of a second between them at the track.
'84 fox convertible. E7 roller block .030 over with Hyper. pistons and stock stroke for now. E7 heads, Weiand Stealth intake, holley 4777, comp cams magnum 290 cam and springs, and complete MSD ignition. MAC equal length shorty headers to BBK O/R X-pipe to dual chamber flows. Electric fan conversion. '92 silver ponys. Just added, UPR non adjustable upper and lower control arms, Eiback Pro drop springs, MGW short throw shifter, billet overflow tank, and a few other billet accessories.
Hitman84 is offline   Reply With Quote
Old 04-18-2008, 09:03 AM   #3
highspeed's Avatar
My suggestion would be longtube headers with 3.55's or 3.73's along with a C&L or JLT intake. This will keep your car with some decent bottom end torque and allow it to breathe with a noticeable HP gain.
Modz Update!!!
WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
  • MAF support brace - '94 GT
  • Maximum Motorsports Panhard Bar
  • Canton radiator overflow reservoir
  • Fidanza or Spec Billet Steel Flywheel - (50oz 302cid 10.5" 157 tooth)
  • T56 Tranny with 5.0L Bellhousing & support brace
  • Maximum Motorsports Tubular K Member
  • Maximum Motorsports Tubular A Arms (std offset)
  • Coil over struts
