Results 1 to 16 of 16
Thread: speedo not working
    Newbie fresh fish!
    Aug 2009
    san marcos
    speedo not working
    I bought a 1998 mustang gt standard and the speedo is not working. The guy that i bought it from said he put a new transmission. I cant remember what year of transmission he said it was a 2000 and up model. He said something about the 98 tranny has a gear for the speedo and the other has a sensor. Well does anyone know what i can do or heard about this so i can fix the problem thanks.
    Dec 2003
    SanAntonio
    Both types of speedo drive in stangs use a gear in the trans. diff is on is a cable driving the speedo the other is an elec signal to the speedo. It still has a gear drive on trans but a converter does the work of the old style cable.
    I cant recall what yr it chgd. You could pull the cluster and see if there is a cable to the speedo or not. Shouldnt be to hard to repair it once you figure out the type you have.
    85GT FACH1 FINISHED
    Oct 2006
    Denton
    his has an electronic spedometer.. i bet money the sensor is missing.
    Newbie fresh fish!
    Aug 2009
    san marcos
    Thats what the guy i bought the car from said something about a sensor can you tell me where to look to see if it has a sensor or what im looking for.
    thanks
    Dec 2003
    SanAntonio
    Same place the cable would go in the trans.. Drivers side of trans tail cone just above the cross member
    The wire needs to be plugged in to it also
    85GT FACH1 FINISHED
  6. #6
    stang user fresh fish! cmtz429's Avatar
    Jun 2007
    S. TX
    Mt odometer is not working, after pi swap. that is weird too.
    I just wanna go fast!
  7. #7
    Dec 2003
    SanAntonio
    Quote Originally Posted by cmtz429 View Post
    You most likely need to replace the gears in the cluster. easy to do and gears are about 25 bucks. My WIFE did hers on the 96 I wasnt allowed to do anything except watch..........
    85GT FACH1 FINISHED
  8. #8
    LoneStarStangs Addict Regular Member TomzStang's Avatar
    Oct 2009
    Buda, Texas
    Quote Originally Posted by mustang hatch View Post
    I have an extra sensor and gear set up out of a 97 standard.
  9. #9
    This is my Baaaaaby! What is SilverStar you ask?  Click here to find out! Mustang_68_Coup's Avatar
    Sep 2005
    San Antonio, TX
    Wes had to do his, too. And all I got to do was WATCH ...
    It's easy and relatively cheap. And common on our age of cars ... apparently the original little gear gets mushy over time. (Mine felt as squishy as cheddar cheese when I took it out and inspected it!! )
    1996 GT Vert
    1968 "Vanilla" Coupe
    - Emo Phillips
    Quote Originally Posted by TheSource
    Young girls are hot as shit but usually stupid as a mother fucker.
  10. #10
    Newbie fresh fish!
    Aug 2009
    san marcos
    Quote Originally Posted by TomzStang View Post
    how much you want for the gear set up let me check to see if thats the problem
  11. #11
    Oct 2009
    Buda, Texas
    Just to be sure, I'm talking about the gear and speed sensor that is mounted in the transmission. Looks like the going rate on Ebay is about $20 + shipping.
    If you are willing to come up to the Cabela's in Buda, I'd let you have it for $10
  12. #12
    Newbie fresh fish!
    Aug 2009
    san marcos
    Figured the problem its the little gear thats behind the gauge cluster where can i buy that do they sellthem local anyone know thanks.0.
  13. #13
    Oct 2009
    Buda, Texas
    When the gear behind the gauge cluster fails, the odometer stops working, but the speedo still works. You can buy the gears on Ebay or a couple of other sites.
    Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
    Speedometer Gears and Odometer Gears. Speedometer Parts
    I've done this on 4 of my Mustangs and one of someone else's. easy
  14. #14
    Newbie fresh fish!
    Aug 2009
    san marcos
    So my speedometer should still work well its not why could that be then?
  15. #15
    Newbie fresh fish!
    Aug 2009
    san marcos
    Im confused need some help is this what im gona have to do to make my speedometer work has anyone done this that may be able to help me out thanks.
    This write up is for the T-45 tail shaft swap. I had to change my tail shaft due to the magnetic speed sensor (found in the 99+ models) as appose to the gear driven sensor (96-98 models).
    Car getting the tail shaft swap is a 2000 Mustang GT. I purchased a rebuild transmission and didn't realize that it had a gear driven sensor. So I had to swap the tail shaft in order to get the speedometer to work (and get rid of the "check engine" light).
    Lets get started. First, we jack up the car (safety first).
    Next, we drain the fluid, disconnect the oxygen sensor plugs, speed sensor, and drive shaft (I couldn't get the tail shaft out without disconnecting both oxygen sensors).
    Now we need to remove the shifter, and accessories within the shifter assembly (sorry, don't know the name but it's in the pictures what needs to be removed) from the transmission. Make sure you remove the pin (shown in one of the pictures below) but make sure you don't lose it.
    Now, remove the transmission crossmember (make sure you support the middle of the transmission in order to avoid stress on the engine mounts).
    Once the cross member is removed, remove all the bolts holding tail shaft. Once removed, you should see a ring (plastic or metal depending on year of transmission. This one is a gear driven speed sensor transmission, so it's plastic with grooves). Removing the safety ring on the reluctor ring was the hardest thing to do for me because I didn't have the correct tool. I used a flat head screw driver and some needle nose pliers.
    This is the reluctor ring (metal ring) I had to use for the required 2000 Mustang GT model. The way I removed the metal ring was by tapping it around it (not too hard and not too soft) until it finally came off. You can put it in the transmission the way it came out, with taps. A fellow AFM member helped me out on this one...thanks!
    Now you can put everything back together. Make sure you put plenty of silicone on the tail shaft. Also, if you don't have a pump to pour oil into the transmission, you could always pour some in through the shifter like I did. I had to use Pennzoil oil because my local high performance shop was out of Royal Purple transmission oil.
    Here we have the 2 tail shafts side by side with sensors.
    So make sure you have transmission oil before you even start the job or you'll end up running around shop to shop looking for oil like I did. I wish I could upload more pictures here but it looks like I'm limited to 15 pictures. If there's anything I left out, again, don't hesitate to tell me.
    I found this on allfordmustangs
  16. #16
    Newbie fresh fish!
    Aug 2009
    san marcos
    Update i figured the problem well today i got under the car checking the wiring with the speedometer tracing them and all. What i found was there was a wire loose and it had a dallas speedcal connected. I got the speedometer to work but the reading is way off so i calibrated it to what the dallasmustang website says to it still reading wrong speedometer is way off any ideas why this can be.
