Old 08-14-2008, 12:56 AM   #1
Keep on Keepin on!!
younggun01's Avatar
Trader Rating: (3)
Send a message via AIM to younggun01
Exclamation Starter question.
I have to replace my starter in my stang. its an 01 bullitt my question is do you have to remove the header to get to it or not?? Anyone done this?? last time i had this done it was through warranty in Houston at a small shop but id rather just do it myself if its not too much of a pain. Thanks
(My Pimp Ride)2001 Bullitt - BBK L/T headers , BBK O/R X-pipe ,flowmaster welded in mufflers, U/D pullies, tri-ax short throw shifter, Steeda timing adjuster, Densecharger CAI, Aluminum D/S, Diablo Predator and wrapped w. sum nitto 555R's!!
(My beater)1979 280ZX-flowmaster , short throw shifter, headers, KnN airfilter,
younggun01 is offline   Reply With Quote
Old 08-14-2008, 04:42 PM   #2
Keep on Keepin on!!
younggun01's Avatar
Trader Rating: (3)
anyone???
Old 08-14-2008, 05:40 PM   #3
Do have stock manifolds or longtubes?
Mystic SVT is offline   Reply With Quote
Old 08-14-2008, 05:47 PM   #4
Keep on Keepin on!!
younggun01's Avatar
Trader Rating: (3)
long tubes... thats what i was lookin at when i was under there if i have to take it off or not..
Old 08-14-2008, 10:33 PM   #5
LOL @ your mom
Trader Rating: (22)
It's a PITA, but you have BBK, they should be easy to come out... 3 bolts hold it in place too.
Old 08-14-2008, 11:36 PM   #6
Keep on Keepin on!!
younggun01's Avatar
Trader Rating: (3)
Thanks Jody
