Old 04-07-2008, 12:34 PM   #1
always asleepn
tulabeast's Avatar
starting problem
Well heres the deal i have a 91 lx 5.0 couple bolts-ons nothing major.When i go to turn it on first crank no probs turns right on runs great.drive it for a while let it get to normal running temp never gets higher than 170-180 max in dead stop traffic then i turn it off wherever i am, go to start it and it barely wants to crank like the batt is dead or dying.It has a brand new batt,starter silinoid(sorry cant spell)high tourqe starter tested the alternator its good.when the car cools down its starts again.
thanks for all the info in advance.
any ideas please
98 gt on the streets.
mod motors suk
Old 04-07-2008, 12:51 PM   #2
You're a freak. Like me.
Stumpy's Avatar
best i can think of is that it's the starter. i have an old 83 Monte Carlo and many moons ago the starter began to go out on it. every time it was cold, cranked right up. when i would drive for a while and shut it off, when i tried to recrank it, it would drag like a sumbitch. so my only suggestion is to get the start checked. outside of that, i'm at a loss.
also,what's up with the pics???
I have come here to chew bubble gum and kick ass and I am all out of bubble gum.
Hope and pray that you will not need me, but rest assured I will not let you down. I'll walk beside you but you may not see me. The strongest among you may not wear a crown. - Citizen/Soldier - 3 Doors Down
Men are natural destructors. We pop right out of the man-womb and start on a life-long tirade of progress by tearing down the Earth with our mighty, man-manly man-fists.
Stumpy is offline   Reply With Quote
Old 04-07-2008, 12:54 PM   #3
always asleepn
tulabeast's Avatar
i just put that high torque starter maybe bout 4 months ago and before that i went thru like 2 or 3 factory starters.i dont drive the car alot is there something maybe burning out my starters.is there a better starter out there
mod motors suk
Old 04-07-2008, 03:07 PM   #4
Evil Angel
Bigdrumma22's Avatar
Trader Rating: (4)
Wink
My suggestion is to make sure you have good grounds and extra don't hurt. On my 84' Chevy truck, I used to have problems cranking it every now and then. I had the negative cable from the battery to the alternator bracket on the block, but it still seemed to be struggling. Talked to a parts guy who simply suggested adding an extra ground, so I added a 2 ga. ground cable from block/transmission to frame and it solved the problem. This is just my experience with starting problems. I saw your car at ANR the other day, it's nice! Sounds good!!
Bigdrumma22 is online now   Reply With Quote
Old 04-07-2008, 03:19 PM   #5
ANRmotorsports's Avatar
Trader Rating: (10)
Its coming back tomorrow so we can check out that problem and the 5 lug swap will get done while its here this week. None the less the car dosnt get along with the owner!!
ANRmotorsports
7190 E.1518 N.
Schertz, TX 78154
New and Used mustang parts.
ANRmotorsports is offline   Reply With Quote
Old 04-07-2008, 05:50 PM   #6
Dumb and dumber
Trader Rating: (18)
Heat shield or high temp wrap to keep some of the heat soak off of the starter would be a good idea as well. As the temps outside go up, so do the under hood temps of all cars this far down south.
Originally Posted by Kayla1GT
LMAO he just told me to suck it!!!!!!!
Old 04-07-2008, 11:56 PM   #7
J5
J5's Avatar
Damn sammy I think you have more shit happen to your car then i've had with mine. Let me know when you get it fixed
J5 is offline   Reply With Quote
Old 04-08-2008, 08:16 AM   #8
UT Sucks
Where is your battery located? How did you wire up the mini starter? What gauge wires are you running from the battery to the starter and ground?
Darren
Old 04-08-2008, 01:40 PM   #9
always asleepn
tulabeast's Avatar
thanks its a problem child but what can i do ill try the ground thing
mod motors suk
Old 04-08-2008, 01:43 PM   #10
always asleepn
tulabeast's Avatar
your car never breaks cuz its a auto and ur wack dont come back to san antonio cuz ill give u proper ass woopn in my car that hates to start.
if my 98 is running ill give you a proper in that one too
mod motors suk
Old 04-08-2008, 01:45 PM   #11
always asleepn
tulabeast's Avatar
Darren
i dont really know how the starter was wired i didnt set it up i was thinkn the same thing bout the wire gauge ill check it out.
mod motors suk
Old 04-08-2008, 01:47 PM   #12
always asleepn
tulabeast's Avatar
heat wrap is a must i def have to do that
mod motors suk
Old 04-08-2008, 03:59 PM   #13
UT Sucks
If it is wired up like most mini starters I would suggest you use 4 ga wire if the battery is located under the hood. If the electrical loads are high then 2 ga will work better. If the battery is in the trunk then go with 1 ga. from the battery to the inner fender mounted starter solenoid (stock Fox).
Battery 12V + to post on inner fender mounted starter solenoid closest to battery - 4 ga.
Battery 12V - to frame ground - 4 ga.
Frame to engine block ground - 4 ga.
From the post on the inner fender mounted starter solenoid that is closest to the shock tower to the male blade connection on the mini starter mounted you only need 10 ga. This is the trigger wire to excite the coil on the mini stater solenoid so it does not pull a large amount of current. From the post on the mini starter solenoid to the post on the battery side of the inner fender mounted starter solenoid use 4 ga. See diagram below.
http://www.powermastermotorsports.com/027___IS_PMGR.pdf
I like to run the wires from the inner fender mounted solenoid to the mini starter solenoid just in front of the motor. I run mine above the rack and pinion and then between the oil pan and the motor mount on the passenger side. The name of the game is to keep it away from the exhaust and where it will not get damaged by debris on the road and pinched by moving parts. I have this done on my T-Bird that has long tube headers and the Coupe with shorties and I have zero heat soak issues with the ministarters. I had more issues with the old style starters than a panhandling crack head.
Hope you get it figured out.
Darren
Old 04-08-2008, 07:16 PM   #14
Dumb and dumber
Trader Rating: (18)
The header is right up on the starter, so I would say that is the problem.
Old 04-09-2008, 12:20 AM   #15
J5
J5's Avatar
Will see when i get back. I don't want you crying to your mom when you get your feelings get hurt. And if you want i'll give you a ride and drop the top so you can dry your eyes.
Old 04-09-2008, 10:12 AM   #16
always asleepn
tulabeast's Avatar
Darren
dam thanks alot. i think some long tubes will let some of that heat get out.i def keep you guys posted
mod motors suk
Old 04-09-2008, 10:14 AM   #17
always asleepn
tulabeast's Avatar
all day baby im ready come get some sucka. ill can probably take you out in the 98 and that car is real slow. you still gonna get that blower. whos gonna install it for you
mod motors suk
Old 04-09-2008, 10:20 PM   #18
J5
J5's Avatar
You still got the white gt. Its either the blower or turbo. I'm thinking of taking it to psi when i get back. But the first thing on my list ist to convert it to stick. Thats going to run around 2-3000 depending on the transmission i get.
Old 04-10-2008, 11:10 AM   #19
always asleepn
tulabeast's Avatar
na i donrt have the white 98 any more i bought a silver 98 but it still aint running hopefully i get it back soon
mod motors suk
Old 04-11-2008, 09:51 AM   #20
J5
J5's Avatar
How much did you get that for. Whats wrong with it
