STAY AWAY FROM GRANETELLI CONTROLL ARMS FOR THE 05
I was almost killed by a set of these.
So i test drive a customers car today due to a claimed noise from the read end upon relase of the throttle to deleration... This car makes about 450 rwhp with nothing more then a whipple and suspension upgrades. Did a viusal inspection and didnt see anything visualy wrong bushings looked good didnt see any kind of problems visualy so we diced to test drive it. i'm dirivng up the road i acellerate mildy from 35-45 and then release the gas to decelerate in gear and BOOM the rear end jumps up in the air and starts swinging around on me By some miracle of god I managed to steer the sliding car into a parking lot entrance limiting the damage to just what the tire did to the fender lip. and some damage to the rim. what happened ? The CAST aluminum end they used in the controll arm failed. The threads flat out just pulled off on the cast end allowing the controll arm to drop down and dig into the ground when i let off the gas and the car was decelrating. I will get pics up later today when i have a chance to remove them off the car but the end was threaded more then half its length into the tube and the lock nut had been tightened .. it did not just unscrew it actualy pulled apart the cast aluminum end failed. Just a warning for those using this controll arm CHECK THEM FREQUENTLY. check the lock nut and see if you can tighten it and pull the end out of the tube with it.
GMS has had several issues with quality control and this is why I do not sell their products .
Coming to a 17" rim near you
GMS sux, this is the 4th story i have read about the control arms screwing up; not just on the 05+ but the new edge also. i will NEVER buy a GMS product. glad ur ok
wow, that's good to know.... glad you're ok. good luck w/ that customer...
t-5 swap, billit quadrant, upr firewall adjuster, steeda tri-ax, custom jb tool and fab one off subframe connectors, 8.8 w/posi and 4.10's with 5 lug axles, tubular upper control arms and southside lowers next, '00 gt brakes, followed by my 306 swap |
wow....crazy....good thing nothing bad happened to ya!!!!! who would dyno tune my stang next fall when i put the s-trim on?????? hope yall get it all fixed up.
1989 LX Coupe 5.0 HP/335 TQ/362 list goes on forever....she slooowww!! |
We do not sell Granatelli products either. For the most part they are cheaper copies of quality products.
#8 | |
Get It?
![]() Glad you were able to pull it through Dean
1 of 1616 Year 2007 Mustang GT,Torch Red, Coupe, Manual Transmission, Dark Charcoal Interior. And Your Is?
