Old 06-03-2008, 06:49 AM   #1
Steering Box ? on my L.
I know that this is tech for Fox Stangs but I have a ? for the FORD Tech's (this means you Larry)on here.
The seal around the steering shaft (were the pitman arm attaches) on my 94 Lightning is leak P/S fluid. ? is can you replace this seal or does the entire box need to be rebuilt?
Any help or tips would be appreciated.
Thanks
Don
Old 06-03-2008, 08:30 AM   #2
the pitman arm seal IS servicable... i dont know how hard it will be to track one down.
Old 06-03-2008, 09:15 AM   #3
Box Foxes Rule!!!
racer99's Avatar
I could answer this but I am not a Ford tech so you will
have to wait for one I guess.
of stupidity!
78 Zephyr,
82 Granada Wagon,
88 Mustang 2.3T
94 GT
Old 06-03-2008, 09:40 AM   #4
☆★LSS★☆
Yes, Ford has a kit. I would recomend to go ahead and do the whole box though. Should be a 3e501 and a 3e502 kit.........
Old 06-03-2008, 09:43 AM   #5
Box Foxes Rule!!!
racer99's Avatar
D7AZ-B ,eh?
of stupidity!
78 Zephyr,
82 Granada Wagon,
88 Mustang 2.3T
94 GT
Old 06-04-2008, 06:24 PM   #6
Thanks Larry.
Ck your PM's
