Old 02-09-2004, 08:47 PM   #1
JOHNP's Avatar
Steering wheel shaking
My wheel shakes between 55-65 mph. I have checked the obvious ... tire pressure, allignment was just done, and have been balanced twice. I was thinking that maybe it was due to my worn ball-joints. Would the ball-joints cause something like this?
JOHNP is offline   Reply With Quote
Old 02-09-2004, 09:56 PM   #2
Yes they could cause the problem but I'd be willing to bet it's the tires.Probably has cupping on the inner edge.:jeff:
Old 02-09-2004, 11:02 PM   #3
"The Hitman"
Hammered's Avatar
I go with the tires on the chakeing...switch the backs to the front...and see if you still got the problem
Old 02-09-2004, 11:10 PM   #4
JOHNP's Avatar
I have rotated them already. The tires are 4 months old... I had them checked and they are OK. I'm thinking if the ball-joints can cause the problem, that's what it is. I had the problem before I lowered the car, but it was more pronounced after I lowered it about 3 months ago. Could a-arm bushings be involved too?
Old 02-09-2004, 11:17 PM   #5
"The Hitman"
Hammered's Avatar
if it is the ball joints you should be able to jack it up and jiggle the wheels/tires and hear a knocking noise...kinda...ya know?
Old 02-09-2004, 11:20 PM   #6
Poultry Savior
ChickInHer01GT's Avatar
Send a message via AIM to ChickInHer01GT
bent rim?
ChickInHer01GT is offline   Reply With Quote
Old 02-09-2004, 11:34 PM   #7
THE OLD SCHOOL MODERATOR
1SLO85's Avatar
Maybe warped rotors. Is it worse when braking?
1985 Mustang GT-Yeah, it's FAST
2009 Hemi Orange Challenger R/T
1SLO85 is offline   Reply With Quote
Old 02-09-2004, 11:41 PM   #8
"The Hitman"
Hammered's Avatar
Dam i love the rip vanwinkle avi....
Old 02-09-2004, 11:56 PM   #9
JOHNP's Avatar
Rims are new and true. The brakes are new as well. It is not worse when braking. Only when cruising around 55-65 MPH it starts. I do have a clunking noise in the front end at low speeds, which I found is the ball joints. I figured that my be the cause of the shaking too.
Old 02-10-2004, 12:03 AM   #10
If the ball joints are extremely loose they can cause the problem you've described.If any suspension component is loose it cannot be contolled by the shock or strut which can cause a shimmy or shake.
Old 02-10-2004, 12:06 AM   #11
JOHNP's Avatar
thank you... JP
Old 02-10-2004, 12:35 AM   #12
thank you... JP
Your Welcome!
Old 02-10-2004, 08:07 AM   #13
True dat! :jeff:
Old 02-10-2004, 03:52 PM   #14
Stalked!
VulvaMan's Avatar
Send a message via MSN to VulvaMan Send a message via Yahoo to VulvaMan
I have the same problem. I recently took my car in for a full suspension / front end inspection and it was all fine according to 2 different techs at two different places. My car didnt shake at all with the brand new tires but quikly started again. I feel its an alignment thing but who knows?
VulvaMan is offline   Reply With Quote
Old 02-10-2004, 04:51 PM   #15
JOHNP's Avatar
How much was the inspection? Where did you go too? Just wondering, because I do all my work myself, but would like to have another person check it before I start replacing things I may not need.
Old 02-10-2004, 06:54 PM   #16
Stalked!
VulvaMan's Avatar
I had it checked by a plac ein Florida colled trick pro motorsports and then in texas I had it done at Midas for $20
Old 02-10-2004, 07:00 PM   #17
in a happy place
TrueBlueVenom's Avatar
turn your rotors to see if that resolves it
Old 02-10-2004, 07:06 PM   #18
JOHNP's Avatar
I think I will get it inspected first this weekend. If they find that everything is ok, I will turn the rotors. Thanks for all the info guys, I appreciate it!!! Sometimes when I post questions on "other" tech sites, all I get is BS or no answer at all.
Old 02-10-2004, 08:47 PM   #19
Stalked!
VulvaMan's Avatar
Ya this is by far the best site I have been on for tech stuff
:jeff: :threegear
Old 02-10-2004, 10:18 PM   #20
A warped rotor can cause that symtom ONLY when braking.From what John is describing it does it at highway speeds while driving.There are alot of possibilities that can cause this.What I personally have seen the most often is a bad tire cause this but of course I work on newer vehicles too.Worn suspension components can also be a cause of the problem and will most likely be on your higher mileage vehicles.I personally have never needed to replace ball joints on a Mustang but I'm sure it is because of reasons I stated above.What I do see go bad most often on Mustangs front ends are inner and outer tie rods and struts and lower steering shafts.Just my 2 cents.:jeff:
