stock rear end
im putting a 10.5 rear rim and a wide tire on the back of my stock car. what will the factory axle/rear end think about this. am i now going to cause damage to these parts with that much more traction just by flooring it? or will it hold up?
Unless you are making a lot of power you will be fine
running a normal 315 radial wont necessarily improve traction. If you buy crap tires, you will haev crap traction regardless of width.
My 315 sumitumos were terrible. my 315 nitto DRs were the win. I would have considered running a 285 khumo MX had I kept the car.
go with the MX, that tire will not hook
do you want traction or not?
its not that bad in real life. it hooks and will handle 5 times better
