Old 08-22-2007, 10:54 AM   #1
97ponylover's Avatar
Sub/Amp Mach 460
Has anybody here added a sub/amp to a Mach 460 system? I've seen the articles but there seems to be some debate as to where to splice into the system.
97ponylover is offline   Reply With Quote
Old 08-22-2007, 11:02 AM   #2
Not hot..
Chili's Avatar
I did but I had it installed.
2004 Torch Red GT
Best 1/8 8.61 @ 81.59
Old 08-22-2007, 11:26 AM   #3
I'm starting to think that is what I might do...
Old 08-22-2007, 11:51 AM   #4
lazer96gt's Avatar
are you trying to keep the factory deck, or going after market? if you're staying with the factory deck, you need to run a Line Out Converter tapped in behind the deck, or at the INPUT side of the Mach amp. It doesn't matter if you tap into the front or rear channel as you will get the same signal (input side only). Only matters if you are going to "fade" your stereo front or rear. Tap into the channels that have the most signal. For example, if you fade to the front you will want to tap into the front channel because the rear would have a lower output from the deck. I say not to tap directly into the speakers because the amps have internal crossovers which would change the frequency of the output. Assuming that you have active crossover or the aftermarket amp has an internal crossover, you want a "full range" input signal. I'm sorry I cannot tell you exactly which wires to tap into but I rarely use factory decks to run aftermarket equip. since the factory stuff has so little control. hope this helps a little.
96 SVT#6858 of 7496
Old 08-23-2007, 08:52 AM   #5
Yes, I'm keeping the factory deck... for now... gotta love the 6 disc changer.
I'll post up the article I read and maybe you or somebody can guide me from there...
Old 08-23-2007, 09:53 AM   #6
lazer96gt's Avatar
no problem. just a word to you though, those factory 6 dic in dash systems are prone to failure so be very gentle with it when you remove and reinstall it. you'll also see a sticker on it that says "Scrap if dropped".
96 SVT#6858 of 7496
Old 08-23-2007, 10:48 AM   #7
GateJockey81's Avatar
Trader Rating: (3)
Send a message via Yahoo to GateJockey81
i had mine done, and had to take it back b/c they ignored me when I told them the NOT to tap into the speaker line, the converter has to be tapped into the AMP to work right. good luck, its worth it
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms shall not be infringed."
GateJockey81 is offline   Reply With Quote
Old 08-23-2007, 01:39 PM   #8
Here's one of the articles but there was another better article that I'm having troubles hunting down.
Mustangworld Subwoofer install to Mach460
Old 09-01-2008, 09:15 PM   #9
Well I finally got around to installing a punch 300 amp and 10" sub i bought back when I started this post... yes, I procrastinate... and holy cow what a difference. I still need to tweak everything and then clean up the wiring in the trunk. It wasn't nearly as difficult as some people make it sound. And for the $125 i spent on the equipment i think it was money well spent.
Old 09-01-2008, 09:16 PM   #10
Baby Noahs Papa AKA Maverick
lobra97's Avatar
look up my thread trouble w/ stereo n speakers. lots of help from guys on here.
"My lil boy is growning up too damn fast"!!
JDM YO!
lobra97 is offline   Reply With Quote
Old 09-01-2008, 09:26 PM   #11
help on tweaking??
Old 09-01-2008, 09:28 PM   #12
lobra97's Avatar
yeah theres a few guys that know all the ins and outs of that stuff. they were gonna install some stuff for me on sun. at mod day but some stuff came up. they know alotof stuff there.
JDM YO!
Old 09-01-2008, 09:30 PM   #13
lobra97's Avatar
ask john#21 he seems to be really experienced, he was talking to me about it a bit at mod day. i have a 97 cobra w/ a mach system also, so should be the same.
JDM YO!
Old 09-01-2008, 09:31 PM   #14
lobra97's Avatar
look up lobra in the search thing, then look up my speaker thread. you'll see it, someone posted some stuff about the system there also. lots of info.
JDM YO!
Old 09-01-2008, 09:54 PM   #15
Cool... i'll check it out... thanks... i just back from playing with it some.. sounds a lot better... it's gonna take me a while to get used to having that bass...
Old 09-01-2008, 09:59 PM   #16
not seeing it???
Old 09-01-2008, 10:01 PM   #17
lobra97's Avatar
thread post #20 by john#21? if not send him a pm, he seems to know a lot
JDM YO!
